Ztec turbo runing lumpy
fiesta mk4 2.0zetec as follows: -2.0 zetec blacktop engine, running OFAB management. -T4 Turbocharger with front mount intercooler, -Port and polished head, -steel spacer plates to lower compression -Two focus RS head gaskets -Rs turbo gear box, brakes, drive shafts. -Cosworth beige injectors -full decat custom exhaust system, -Walbro Fuel pump -leather recaro seats, Too much to list, to finish this project off, i have been informed that the ecu will need to be mapped in order to run the engine smoothly, as at the minute the Engine is running lumpy as the air/fuel ratio is out of sync. Wht wud the main causes for runing lump i mean worse case wht wid it be or take to run proply cheers if any 1 can help
The annoying ginger guy
Beiges don't really go too well on a zetec turbo there ok but tend to run lean, I'd take it to a tuner and see what they suggest as they may be able to us your setup and make it run smooth, or recommend good managment/components
Wrong chip, wrong injectors
You need a zetec turbo chip and a matched injector too the chip, msd sell these for £250 for the chip, totally wrong ignition and fueling for a zetec when running cvh chips
Just a tip, check out boost monkeys ofam ecu, plug and play with your loom and fully mappable, £389.99, this way you can pick your injector before mapping.
And another, why use spacer plates, when a st170 bottom end and focus rs 1.8mm head gasket with your head and st170 valve springs is proven over 300bhp
Why would you bother?, it's a ticking time bomb at 200bhp, also a t4 turbo is too big for the spec, a t3 from a cosworth would be better
Otherwise I would stick the st170 valve springs and bottom end in
as said above its a bit of everything thrown together by the sounds of it. dump the frst ecu and get something modern and mappable
