Small turbo head
Hi I have a spare head and was thinking of using it on my next build what sort of power can these be taken to looking for 500hp ish running l8 so no silly ecu probs
Cheers steve
Cheers steve
IIRC they are more restrictive without being worked than a normal 4x4 head. You also have to use a YBP cam cover as the regular Cosworth one has a different bolt pattern on it.
I think so? There are differences in where your water temp sensors etc go (front of head for the CTS and inside the cam cover for the dash water sensor), so your wiring loom may need modded to suit.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
