Vacuum Hoses SP
29-10-2013, 08:16 PM
Vacuum Hoses SP
where do the vacuum hoses go to and from on a 4x4 escos?
they are all off at the moment and dont have a clue where they have to go to and from, i also want to buy some new hose to do them with anyway.
any ideas?
rob
31-10-2013, 04:10 PM
Pretty easy,
Fuel reg
Map sensor
Dumper
Boost gauge
Purge valve if still fitted from carbon canister.
The fuel reg and map sensor should be on there own lines, and un cut as they are engine critical.
31-10-2013, 05:44 PM
31-10-2013, 05:52 PM
Monte 087
Quote:
Originally Posted by
Billy_RS
What about Amal valve?
That gets pressure from the Turbo not the plenum
31-10-2013, 05:54 PM
paul16v
I've got mine in bits and the Amal valve has 3 ports. One goes to the actuator. One goes to the turbo compressor housing and the 3rd goes to the ????
31-10-2013, 06:17 PM
31-10-2013, 06:22 PM
The Escort cosworth doesn't use an Amal valve,
The valve the escort uses is only 2 port, one going to the air box the other to the jetted tee piece
31-10-2013, 06:25 PM
James @ M Developments.
Makes sense now. Cheers
31-10-2013, 09:30 PM
thanks guys.
ive seen kits that kind of lock on, are they worth having or a load of poo...
other than that just any vaccuum pipe will do i suppose, all the pipes have joiners!
there is one going in to the car aswell seems to be near the ECU? maybe thats going up to the boost guage.
Fudgey
21
30-09-2015 06:19 PM
