will escort cos front calipers/disks fit on a s2?
Old Mar 20, 2005 | 09:44 PM
mrviper's Avatar
mrviper
Default will escort cos front calipers/disks fit on a s2?
i got a set of escort cosworth disks calipers and pads that was fitted to my 2.0 zetec fiesta using the washer and long bolt trick (fiesta now being scraped)
so im just puting up a post to see if thease can be transferd to a s2 escort
cheers!
Old Mar 20, 2005 | 10:13 PM
AKRS1's Avatar
AKRS1
sierra or escort 4X4 cosworth calipers will fit with 2wd sierra cosworth
Old Mar 20, 2005 | 10:24 PM
mrviper's Avatar
mrviper
so i need to get some 2wd cosworth disks and the escos calipers will bolt str8 on ?
Old Mar 20, 2005 | 10:27 PM
AKRS1's Avatar
AKRS1
yeah mate on standard rims too but it will be tight but they will go on. got them on mine nice set up i think you need couple of 1mm washers
Old Mar 20, 2005 | 10:34 PM
mrviper's Avatar
mrviper
shame i cant use me escort ones there fooking cross drilled and grooved
how much are 2wd cos disks then ?
Old Mar 20, 2005 | 10:41 PM
AKRS1's Avatar
AKRS1
cheapest ive seen are black diamond cross drilled and grooved from jondel motorsport (08007313934) for £130 and a set of 4wd pads are £50 but you get a £6 discount if you buy both together and its free p+p. I just got black diamond discs from jamsport in northampton but cost more expensive because i went for the ebc red stuff pads which were nearly £80. 4X4 cosworth pads are well expensive the only downside to having the set up dont know why they are expensive they look the same as any other pads
Old Mar 21, 2005 | 08:34 PM
stifla's Avatar
stifla
my mate does break conversions for s2s and they are awsome. ive got some on mine and they stop on a penny forget cozzy at front just do the rears. he does 300mm discs and you use your original s2 calipers but he supplies you with a set of stainless high tensile brackets,washers and bolts and they took me 20 mins to change over
so you get 2 300mm discs, brackets, washers and bolts for £130 all in and like i said they are awsome
PM if you want any more details or pics trust me you wont be dissapointed
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
