Running problems with my 2YB engine
Old Sep 20, 2013 | 05:22 PM
Steve Percival's Avatar
Steve Percival
Question Running problems with my 2YB engine
I have justfitted a 2lt Sierra turbo Cosworth 2YB engine into my kit car, the problem iswhen I start the engine up with the heat sensor fitted the car enginestarts after a little asking then dies very quickly, when I take the sensor offline the engine runs but at quite high idle speed but will rev OK. Any clueswhat is going on?
Old Sep 21, 2013 | 07:40 AM
nixon_2wd's Avatar
nixon_2wd
The blue one? Known to be a lot of problems with those, find a replacement and your probably sorted.
http://www.ebay.co.uk/itm/Ford-Coswo...item3f181afd77
or OEM:
http://www.ebay.co.uk/itm/New-Ford-E...item27d7637be1
Old Sep 21, 2013 | 10:34 AM
Steve Percival
Question
Thanks for that, I did buy a new blue sensor to see if it would clear t6he problem. Have you any idea what other sensor may work
big_Rad
Sep 15, 2017 09:36 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
