Anyone repaired a stripped spark plug?
Old Sep 20, 2013 | 08:29 AM
Alps Pacino's Avatar
Alps Pacino
Default Anyone repaired a stripped spark plug?
Was just wondering if anyone has repaired a stripped spark plug hole and if putting something like a helicoil in there would stand up to the compression in the engine? That's if there is enough meat on the head left to do it in the first place.
Car is an e36 m3 evo if it makes any odds.
Cheers Mark
Old Sep 20, 2013 | 08:52 AM
Heitmann's Avatar
Heitmann
Cheers Mark
I know of a guy in Denmark who have done it to his 2wd cosworth - with success
Old Sep 20, 2013 | 08:53 AM
adam151082's Avatar
adam151082
I know someone who done it on a C20XE. They didnt take the head off but I would to save the cuttings falling in.
Old Sep 20, 2013 | 08:58 AM
Alps Pacino
Yeah I was planning on doing it with the head on tbh as I might be buying it to use as a track car so want to keep costs down but it might turn out to be to nice to track but need to go have another look at it when I get home from work.
Old Sep 20, 2013 | 10:15 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
I do it every day, its childsplay on a bench, but you need to make sure you get.as much swarf out of the engine as you can before start up. ideally grease the tap and blow it out with an airline. most soark plug taps have a pilot nose, so you jist screw it into the knackered old thread. make sure your piston isn't at tdc though, because you might hit it with the tap
Old Sep 20, 2013 | 02:35 PM
adam151082's Avatar
adam151082
I would have a hoover as close to the tap as possible if your not removing the head. Good tip with the greese though, that should hold some swaft/cuttings
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
rsguy
44
Sep 29, 2015 03:29 PM
deathrider666
Sep 28, 2015 06:12 PM
