omex 600 sync problem
Old Sep 18, 2013 | 08:13 AM
kev 3dr's Avatar
kev 3dr
Default omex 600 sync problem
My brother is building a mk2 cortina with a jag xlr supercharged v8 got a omex 600 with a omex base map, problem were having is will spark only now and again eg cough splutter then just carry on turning over with no spark but still seem to be getting fuel ok, anyone got any ideas or had this problem before ??
Old Sep 18, 2013 | 10:06 PM
stevieturbo's Avatar
stevieturbo
C**t
You're saying a sync problem, so surely you're already doubting cam or crank signals ?
So have you checked these ? Are you getting a usable signal from both ?
And if it isnt getting a suitable crank/cam for sparks, then it could not be fueling correctly either.
Is there any sort of logging or a scope to check these signals ? Or any error reporting or diagnostics for invalid crank/cam triggers ?
Old Sep 18, 2013 | 10:44 PM
Cardie's Avatar
Cardie
Pretty sure Omex 600 will spark with just a crank signal, plug it in and have a look.
Old Sep 18, 2013 | 10:54 PM
stevieturbo
C**t
Most aftermarket ecu's can run off crank only. Whether that's how they are set up or not is another matter.
And spark and correct spark are two different things.
Kev does suggest a random spark, or at least irregular. So it would imply a dodgy crank signal of some sort, assuming the actual hardware installation is sound as far as wiring and coils go, as well as setup for these items.
Old Sep 19, 2013 | 07:06 PM
kev 3dr's Avatar
kev 3dr
Steve weve tried a different crank and cam sensors just to make sure and theyre using standard brackets/triggers and double checked the wiring and cant find anything obvious also sent the base map back to omex yesterday morning but heard nothing as yet,
Old Sep 19, 2013 | 07:14 PM
stevieturbo
C**t
There is little sense swapping sensors for the sake of swapping them
Check their output, that's what matters
Old Sep 19, 2013 | 08:23 PM
kev 3dr's Avatar
kev 3dr
Its all reading we think going off laptop values
Old Sep 20, 2013 | 09:26 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Omex 600 doesn't use a cam sensor
Old Sep 20, 2013 | 11:01 AM
cozy777's Avatar
cozy777
had this with my 710 would turn over fire then loose signal , omex had to do an update??? so they told me then it was ok, check with omex there very helpful
Old Sep 20, 2013 | 04:55 PM
Will Pedley Racing's Avatar
Will Pedley Racing
willpedleyracing.co.uk
Kev,
With the laptop connected - click the 'Start' icon, then in your Parameters you should have a box titled "Stat Sync" - this needs to change from OFF to ON during cranking. If it's doing that, then the trigger pattern programmed into the ECU and the trigger wheel references are compatible and your problem is elsewhere.
Did OMEX make you the wiring loom or have you done it yourself? Have you wired the ignition/fuel in cylinder order or firing order?
As Martin said, OMEX600 doesn't use a cam sensor input.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Tank Mike
Sep 14, 2015 03:56 PM
