2.9 12V Supercharger
Old Sep 17, 2013 | 02:44 PM
Marc Bourton's Avatar
Marc Bourton
Default 2.9 12V Supercharger
Hello, looking to supercharge a 2.9 12v V6 recommendation on which super charge is best and any other engine mods I would have to do?
Thanks
Oh and if anyone is selling a good 2.9 or the supercharger let me know
Old Sep 17, 2013 | 03:25 PM
dojj's Avatar
dojj
Resident Wrestling Legend
get one from a merc kompressor and they will be fine
not enough space under the bonnet of a sierra to really make them work as they should so they'll have to be bolted to the side and run via pipes and stuff rather than directly onto the inlet manifold
Old Sep 17, 2013 | 03:35 PM
Fil's Avatar
Fil
ELASTIC BAND
SC if you really want, but better off and easier to twin turbo it. better still 24v it , then twin turbo it
Old Sep 18, 2013 | 07:55 AM
Marc Bourton
I wanted to SC as it's something different
Old Sep 18, 2013 | 10:11 AM
Thrush's Avatar
Thrush
Irritating c........
You're biggest problem is likely to be getting a cradle to mount the charger on, as opposed to the charger itself or the associated pipework. You either need to get an original item made for the job, or find someone with a charged engine, and borrow the cradle to get a copy made up. Just guessing at it with a tape measure and a protractor isn't going to work - that charger needs to be lined up spot on for the belts and pulleys to work properly and true.
Old Sep 18, 2013 | 10:26 AM
XRT_si's Avatar
XRT_si
As above, and I'd go for an Eaton M90, which is off a Jag XJR and similar.
Old Sep 18, 2013 | 09:20 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Power Engineering have fitted Eaton M90 superchargers to 2.9s. See if you can get hold of Sparkplug on the XR Owners Club forum, he has one fitted to a 3.7 conversion.
Old Sep 18, 2013 | 09:33 PM
Cut a hole out the bonnet and get the super charger to stick out of the bonnet.
Old Sep 21, 2013 | 01:05 PM
Marc Bourton
I did thing the same.
I have contacted Power Engineering see what the say
Old Sep 22, 2013 | 01:44 PM
Churtz's Avatar
Churtz
Definitely an M90.... The merc version (m62 I believe) wont have enough puff for your engine... I used to run one near its max rpm to get 12psi on a 2.0 zetec.
yatta
May 21, 2016 10:31 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Flatlinedan
Sep 18, 2015 12:41 PM
markk
Sep 9, 2015 08:11 AM
