Cylinder Head building!
Old Sep 15, 2013 | 10:43 PM
lewis.philcox's Avatar
lewis.philcox
Default Cylinder Head building!
Hi Guys,
Got my self a bare efi cylinder head which i need to build the question i have is what size are the standard valves? and where can i get them?
as for the rest like springs etc i have a piper 285 cam tappets, springs etc which i will transfer over should i just take all the rocker arms and everything to or can i get new ones?
If so would any of you guys use motor factor bits from APD, GMF or GSF etc?
Thanks
Lewis
Old Sep 15, 2013 | 10:49 PM
theheap's Avatar
theheap
Probably cheaper to buy a used head then buy new valves
Old Sep 15, 2013 | 11:06 PM
lewis.philcox
ive got valves as ive got another head but i just wondered as i was doing a build if i should put new valves in
Old Sep 16, 2013 | 12:36 AM
rsmark86's Avatar
rsmark86
i got a complete head minus cam, with everything else
but no need for new rockers, not sure if the valves are the same from you old one to new as its 25+years old and could have had all sorts of stuff done in that time, best to get an engine builder to measure it all up to be 100%
Old Sep 16, 2013 | 04:36 AM
lewis.philcox
i did see that mark could you PM me a couple of pics?
Old Sep 16, 2013 | 05:53 AM
rsmark86's Avatar
rsmark86
yeh i could take some later, its still on the engine lol
Old Sep 16, 2013 | 06:52 AM
Ben26's Avatar
Ben26
Ive got a set of turbo valves if u need ??? Just know the turbo valves are different than anyother cvh valve
Old Sep 16, 2013 | 08:28 AM
theheap's Avatar
theheap
I thought all 1.6 cvh valves were the same? I say this because I have two 'turbo' valves in my carbed cvh
Old Sep 16, 2013 | 12:03 PM
mgtkr1's Avatar
mgtkr1
the cvh turbo came with big valves as std, im assuming this iswhat makes the turbo head unique to other cvh heads
Old Sep 16, 2013 | 02:04 PM
lewis.philcox
I've got a set. I have 3 cylinder heads now haha I just wasn't sure if it was worth putting all new valves in howvever if marks head has 30k or whatever it was on it then I might as well use that and put my piper cam in!
Old Sep 16, 2013 | 02:35 PM
Thrush's Avatar
Thrush
Irritating c........
Disappointed with this thread. Expected to see a building made from cylinder heads.
Old Sep 16, 2013 | 03:03 PM
haz87's Avatar
haz87
No it didn't.
Old Sep 16, 2013 | 03:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The only difference between heads is casting thickness (some can be opened up more than others), some came with oversized cam and/or lifters and S1 heads had sodium filled exhaust valves.
Obviously EFI/MFI have different inlet port shapes too before someone says it! lol
Old Sep 16, 2013 | 03:44 PM
mgtkr1's Avatar
mgtkr1
Originally Posted by haz87
No it didn't.
oops. the cvh had fairly big valves, I just thought this was exlucive to the turbo's. what are the reasons for the s2 not having sodium filled valves? cost cutting or just that the material was up to it without the need
Old Sep 20, 2013 | 05:30 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No idea! lol
massivewangers
30
Oct 1, 2015 07:40 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
