How to wire new rad fans up so they're on all the time ?
Hi All,
As above really, have just fitted a new alloy rad and twin fans to my van and would like to have the fans running all the time as opposed to being controlled by the engine temperature - how's best to do this ? I'm no spark myself so will have a go if it's simple or is it a job for a pro ?
Any help much appreciated !
if it uses a fan switch, then just permenantly earth the switch feed to trip the fan relay constantly.
Only do it if your fan relay is powered by an ignition run only circuit.
You dont want it running when ignition is off and you dont want it running during the start phase.
In fact i cant see why youd want it running constantly in the first place..... it wont be doing anything whatsoever except loading up your alternator and draining a few bhp off the engine until the thermostat opens.
Usually theres 3 connections, wire to ignition, wire to relay then switch, earth back from switch. Then last should be to earth. Use a decent gauge wire because it will burn straight through it!!
That said. I've been there! Never again!!!
What sort of temperature are you seeing and what are you monitoring it with ?
Running fans constantly is no good at all.
Just normal use, will never see a track. Not monitoring it with anything, just my gut feeling ! My Saph and my 7 series (I know completely different kettles of fish) seem to take ages to warm up or get up to temperature but my van (just an Escort 1600cvh) seems to be up to temperature within like 30 seconds of being started up ! It never overheats and the old fan used to cut it and cool the engine as it should, it just always seemed extra hot to me !........ but thanks to everyone for the advice, I'll stick to getting it wired up properly !
Bloody ell mate. Defo no need for a "sparky". Could be as simple as a fooked stat. If u have a spare one then change it. If not run the engine without one for the afternoon and see if the same thing happens ??
If you run the engine without the thermostat for a day you know that the rad is always getting coolant through it! this means that if you are moving (50mph plus) you will be getting lots of cooling (and I do mean lots). your engine should not be getting hot but just operating temp. (can take a little time) If this is the case all is well fit new thermostat. If not your will need to work out where the blockage is or if your water pump is not flowing the coolant properly!
If its a turbo?
Msd " up rated fan switch" and 82 degree thermostat will help
Also people say the 82 degree thermostat didn't change anything but from my experience it only really works with the up rated fan switch, don't know why but its true
Swirl pot kit
Turbo cooler kit
Also I've found 1x 12" fan works better than 2x 10" fans, again I don't know why but it does for me
Swirl pot kit
Turbo cooler kit
Another thing, fit a temp gauge as the temperature sensors on sale today are all crap and the idiots at ford sell you the wrong ones so a lot of the time read wrong
Put a aftermarket gauge in and see what it's doing for sure
there is several reliable routes you can take to getting the fans on for longer or at a lower temp but you need to address why its getting hot in the first place
if it warming up that quick then a blocked thermostat is most likely (Ł10 and half hour to swap) , try to get a "summer stat"
if thats not the cause then it could be a knackered water pump / running too lean / headgasket / the list goes on
run it till its up to temp then feel the radiator , it should be warm all over , if not then again - thermostat or water pump
as for the fans , i swear by the adjustable thermostats from kenlowe , its a probe that slides into the fins on the rad and is adjusted to cut the fans in wherever via a dial , easy enough to wire up too
also, if you wanted to wire them on permanent then i would run them through a relay (or 2 if the current draw is high) which is switched by the alternator so they only run when the engine is running
Just a gut feeling....
WTF.
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
y4n
Aug 17, 2015 12:12 PM
