Afr on idle with Greys?
Old Sep 12, 2013 | 08:03 AM
stecozz's Avatar
stecozz
Default Afr on idle with Greys?
Mines around 12.4 afr on idle running grey injectors,is this a bit rich?
Old Sep 12, 2013 | 09:06 AM
Jay,'s Avatar
Jay,
Sponsor
yes but you wont get it much better on greys
Old Sep 12, 2013 | 09:53 AM
Ben26's Avatar
Ben26
is that at normal operating temperature ????
Old Sep 12, 2013 | 10:05 AM
luke19790_3's Avatar
luke19790_3
Mine was around 14.7 on greys. But it was a zetec
Old Sep 12, 2013 | 11:30 AM
stecozz's Avatar
stecozz
Yeah fully warmed up,think its how it is with greys in a cozzy i guess
Old Sep 12, 2013 | 12:00 PM
Ben26's Avatar
Ben26
Will that pass an MOT then ?
Old Sep 12, 2013 | 12:34 PM
stecozz's Avatar
stecozz
It will at the mot garage i go to
Old Sep 12, 2013 | 01:52 PM
Ben26's Avatar
Ben26
Lol. Nuff said.
Old Sep 14, 2013 | 04:52 PM
costina's Avatar
costina
Live long and prosper!!
Depends if your running a closed loop system? tbh if there mapped correctly it should be fine. Any idea what % the co is?
Old Jan 2, 2014 | 04:28 PM
Karl's Avatar
Karl
Norris Motorsport
12 - 12.5 :1 AFR at warm idle is usually the best AFR to give stable idle when using 403's.
Due to the dreadfull spray pattern of 403's the vast majority of YB engines have a very lumpy idle when trying to idle at anything near lambda 1. (14.7 :1)
A very healthy engine with std cams will usually be ok at around 13.0:1 with 403's, but in general best to run them slightly richer to ensure a good quality idle.
Remember this is only at idle folks and will cause no harm to the engine at all!
Old Jan 2, 2014 | 04:43 PM
Jay,'s Avatar
Jay,
Sponsor
A qualified answer
Old Jan 2, 2014 | 05:22 PM
Mungus's Avatar
Mungus
Awsome..... I had the same question with mine which idles at around 13.5:1, which idles reasonably well.
Karl, need to book the car back in with you for a setup please.... you busy?!
Huw
Old Jan 2, 2014 | 05:33 PM
Mark Shead's Avatar
Mark Shead
The greys are a average injector driven by a old ecu. See how much better they work on a aftermarket ecu.
Mark
Old Jan 2, 2014 | 05:38 PM
Mungus's Avatar
Mungus
Mark
Hi Mark,
How you doing? Long time!
Working my way to that but means not available at the present time.
Huw
Old Jan 2, 2014 | 05:41 PM
Mark Shead's Avatar
Mark Shead
Originally Posted by Mungus
Hi Mark,
Huw
Hello. Huw
Doing really well thanks.
Mark
Old Jan 2, 2014 | 05:47 PM
James @ M Developments.'s Avatar
It's not really of any use on an Escort Cosworth then as it will never be road legal at 12.5:1 afr
Old Jan 2, 2014 | 05:48 PM
Mark Shead's Avatar
Mark Shead
It won't without a cat either lol.
Mark
Old Jan 2, 2014 | 05:51 PM
No, but they should run a cat.
I'm just putting one on mine so it's road legal again, removable for track days etc but it flies through a cat test
Old Jan 2, 2014 | 05:54 PM
Mark Shead's Avatar
Mark Shead
Tech the best way of doing it.
Mark
Old Jan 2, 2014 | 09:14 PM
Karl's Avatar
Karl
Norris Motorsport
Yes the weber IAW ecu's are old but a more modern ecu does'nt help with bosch 403's. They have a very shallow angle pencil spray pattern, which means the atomisation of the fuel is very poor.
If you monitor HC levels at idle when using 403's they are lowest when running the engine slightly richer. (i.e. around 12.5:1) It's quite evident in the engine tone too, with a noticably lumpy sounding idle as you lean the idle off towards 14.7:1.
This issue is not evident at all with Siemens 3102 injectors which have the same flow rate as 403's.
Old Jan 3, 2014 | 05:42 AM
Jay,'s Avatar
Jay,
Sponsor
Which is a common known fact so im a bit puzzled to the fact how a modern ecu can change this as to my knowledge you would need to change the nozzle ect to get the above to happen not spend 2k plus on another ecu
Old Jan 3, 2014 | 08:03 AM
stecozz's Avatar
stecozz
As my car is mapped using grey 403 injectors is it possible to just fit more modern siemens or would it need a new remap?
Old Jan 3, 2014 | 08:35 AM
Staffi's Avatar
Staffi
Agree totally Karl, mine on Greys is so lumpy on idle, can't wait to get it setup again with new injectors etc tbh.
Yes you'll need a map
Old Jan 3, 2014 | 08:59 AM
stecozz's Avatar
stecozz
Instead of paying out for a full remap could my chip be just sent back to to scs who mapped it and have it modified?
Old Jan 3, 2014 | 10:38 AM
cossiedave's Avatar
cossiedave
Mark
Mines on 8 x grays running all at the same time on sm4 ecu and i see 12.9 to 13.2 at idle thanks to mad
Old Jan 3, 2014 | 11:12 AM
Mark Shead's Avatar
Mark Shead
Until next time and it will be leaner
Mark
Old Jan 3, 2014 | 12:09 PM
cossiedave's Avatar
cossiedave
Mark
Nice what will you do then
Old Jan 3, 2014 | 01:48 PM
Mark Shead's Avatar
Mark Shead
Press a couple of buttons
Mark
Old Jan 3, 2014 | 02:40 PM
Jan300's Avatar
Jan300
I havent any problem to get afr between 13.4-14.7 when mapping on L8 ecu.
Old Jan 3, 2014 | 04:48 PM
Jay,'s Avatar
Jay,
Sponsor
Mark
KER CHING
Old Jan 3, 2014 | 04:52 PM
cossiedave's Avatar
cossiedave
Mark
Lol funny
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fil
Sep 30, 2015 12:08 PM
