Cam and follower issues
A few month back I replaced my dizzy for a rebuilt one and ever since it has had a slight top end tap that rises with revs and a slight misfiring, also the last two days it has been really tappety on cold start for a few seconds.
Is there any way to check followers by just removing rocker cover?
What exactly am I looking for?
And can anyone recommend where to buy a replacement kit of good quality, I don't want to upgrade it as im on a tight budget just an oem one will do
Thanks
Thanks
There are no good quality standard replacement lifters any more I'm afraid and if there were you cannot change them without changing the cam at the same time, they work harden as they run in so your old cam would tear the new lifters apart.
The only cam kit I would recommend or fit is a Newman one, but that's around £400.
But it is odd that changing the dizzy has made it tap, coincidence maybe?!
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
CrOwSoN15
Sep 14, 2015 11:33 AM
