Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus burning oil
Old Sep 5, 2013 | 08:05 PM
James B's Avatar
James B
Default Focus burning oil
Ive got a 2006 mk2 1.6 Focus, last Saturday at work I checked the dipstick and it was essentially dry. Luckily opposite work is a Halfords so I went and bought Mobil 5w30 as it was only £23 as was Halfords own.
Now my concerns.. I serviced my car about May I think it was as its done annually and I bought it May 2011.
It was last done with all ford service parts.
Its developed a tappet sound, has a sooty exhaust tip, was a pig to get through emissions test as it kept dropping below or going over limits, and as above it had burnt almost all the engine oil.
Im assuming its burning as there is no signs of leaks, no oil patchs as I park in the same place at home and work every day and the sump etc is clean. Also the sooty exhaust tip.
I do about 200-250 miles a week for work in it pretty much all motorway mileage.
Any ideas?
Old Sep 5, 2013 | 08:13 PM
Cardie's Avatar
Cardie
Whats the milage on it?
Old Sep 6, 2013 | 06:50 AM
James B's Avatar
James B
80k timing belt changed
Old Sep 6, 2013 | 08:21 AM
Brendan's Avatar
Brendan
struggling with reality
I would try a compression test and see what you get! Especially if one cylinder is low.... Could it be rings?
The only other time I have seen cars or vans burn oil is if a turbo seal goes and oil is sucked in to the inlet manifold then burnt with the fuel!
You didn't say if yours was a 1.6 TD or not!
Old Sep 6, 2013 | 08:58 AM
Rowe's Avatar
Rowe
Skint
my 1.6 used to drink oil.
It happens. Can either be rings or stem seals
Old Sep 6, 2013 | 11:49 AM
James B's Avatar
James B
1.6 petrol, sorry.
A garage done a free compression test and reckons it was "about right" but I don't really trust the guys opinion..
Old Sep 6, 2013 | 12:16 PM
It's Czech Mate's Avatar
It's Czech Mate
Its classic once you run a sigma low on oil, it wont be long till it dies, seen it a hundred times
They love regular oil changes
( this is the exact reason the early sigma's with the silver cam cover are known as 'unreliable', because they are prone to problems once run low on (dirty) oil
If it was mine i'd try to get rid asap
Old Sep 6, 2013 | 05:53 PM
James B's Avatar
James B
It still seems to drive fine, still doing 38mpg weekly and its only the first time its been without oil and it hasn't been for long as I check it often
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
