2001 Mini one using oil
Old Sep 1, 2013 | 07:09 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default 2001 Mini one using oil
Hi guys bought my misses a Mini One from the Auctions 85k FSH etc
I gave it a full service just after I got her it and its now on 86500k and I have had to put oil in it more then once not massive amounts, maybe a litre-ish or a bit more....
My question is should they burn so much oil? I also fitted a new radiator as it was leaking but I'm still topping it up every now and then?!.....I done a sniff test and all good and it doesn't get hot at all
Should of stuck to the trouble free mk4 golf that had done 170k and she had for 8 years trouble free!
Any help appreciated
Old Sep 1, 2013 | 07:11 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
They suffer with, the o ring round the oil filter and oil coolers
Old Sep 1, 2013 | 07:18 PM
Adam.'s Avatar
Adam.
I did a cooper s with that problem last week lol
That's all good
No drips on the drive or leaks
No blue smoke
Old Sep 1, 2013 | 07:22 PM
gingerturbo
What's the clutch fee like as I've done a rear main seal on a mini too
Old Sep 1, 2013 | 07:26 PM
Adam.'s Avatar
Adam.
Biting point does feel lazy like you really have to rev it to pull away
Old Sep 1, 2013 | 07:31 PM
gingerturbo
If its got a pretty good clutch you won't even notice the leak as it will soak up the oil then burn it off, drill a hole in the bell housing unless its got a squash plate between the block/box
Old Sep 1, 2013 | 07:42 PM
studabear's Avatar
studabear
I've seen a few mini's partial to a drop of oil.
A friend had one with the engine replaced under warranty that was guzzling oil, the replacement wasn't much better
Old Sep 1, 2013 | 08:12 PM
PAUL S's Avatar
PAUL S
My exes has always drunk the stuff like crazy from new, about a litre every 600 miles. She leaves it now until there is virtually nothing left in the sump. Luckily not my problem any more when she blows it up
Its only on 40,000 miles now and is over 10 years old
Csm's Avatar
Csm
A workmate has had one a few years now and since after the first few weeks of ownership he moaned that it liked the oil. I believe some of the petrol beemers e46s were partial to it aswell
Old Sep 1, 2013 | 08:14 PM
Adam.'s Avatar
Adam.
Its like owning 2 RS turbos lol
Old Sep 2, 2013 | 11:36 AM
daveb_lives's Avatar
daveb_lives
I've got a cooper a 03 plate and it uses about a litre every 1000 miles.
Common issue on them, just keep an eye on it but nothing to worry about!
Dave
Old Sep 2, 2013 | 11:48 AM
SiZT's Avatar
SiZT
Rear main seal, sump gaskets, rocker cover gaskets, spark plug tubes. Basically if it can leak oil it usually does What oil did you fill it up with?
Old Sep 2, 2013 | 07:05 PM
Adam.'s Avatar
Adam.
Recomended 5w30 from the motor factors
Old Sep 2, 2013 | 08:25 PM
gingerturbo
Sounds rear main to me?
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
