Nice 4x4 parts for sale
Folks,
Due to me investing in other things more important i'm taking a break from my project until the time is right again.
Some of you may no my project and prior to its stripping phase all parts were more or less brand new, since then parts have been stored at Reyland who was going to stroker my engine, so engine is in a stripped state but block is complete. Engine had originally only done roughly 2000miles from a fresh new build, i ran it for 3 months without fault on low boost due to running in, below is the original spec.
Cosworth YB. 200 engine
Garrett T3 turbo
All new lightened and balanced bottom end
Low compression pistons
Gas flowed head
BD10 cams
Standard 4x4 dark blue injectors management
So i have for sale:
* 200 block, only done 2000m from new build, no cracks bore size 91.75mm £700 prov sold as complete block
* 4x4 Flowed head, unsure on the porting extent, in perfect order = £450 Sold
* 4x4 st/st crank, done approx 2000m from last engine build = £450 prov sold with block
* 4x4 standard inlet complete with blue inj and throttle body = £100
* Red big turbo rocker cover in very nice condition = £80
* Garret T3 Turbo, not been used in a few years but prior was perfect working order = £100 prov sold
* BD10 cams = £80
* Low comp pistons with yb con-rods, unsure of spec on pistons = £200 with block
* 4x4 BT engine loom = £80 prov sold
* 4x4 gearbox in perfect working order = £250 sold
* 4x4 oil pump-water pump = £50
* 4x4 sump unit = £100
There will be more, most parts are still sitting at Reyland, im hoping to be down next month to pick what i have there.
Prices are ono, postage is extra
Thanks Robert
Garrett T3 turbo
Gas flowed head
BD10 cams
So i have for sale:
* BD10 cams = £80
Thanks Robert
I'll take the engine loom fella, can collect from Aberdeen a week Thursday when I get back. I can pay in advance or cash on collection, should be on the beach for midday/afternoon time.
155lee
Aug 14, 2015 11:21 AM
