focus rs pistons and rods???
Old Aug 29, 2013 | 10:40 AM
mk1trb's Avatar
mk1trb
Boost Junkie
Default focus rs pistons and rods???
Will they fit in a silvertop zetec
Old Aug 29, 2013 | 10:55 AM
Ben26's Avatar
Ben26
if its a 2.0 then yes
luke19790_3's Avatar
luke19790_3
Yes
Old Aug 29, 2013 | 05:29 PM
mk1trb's Avatar
mk1trb
Boost Junkie
what about the st170 pistons and rods then as there the same arent they?
Old Aug 29, 2013 | 05:41 PM
luke19790_3
Yes they will fit
Old Aug 29, 2013 | 09:27 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
they're not the same as the Focus RS rods + pistons, but they are the same bore and big end sizes so they will fit.
And just to note, ST170 pistons are not forged, they're only normal cast ally the same as any other zetec, although they are a unique design.
Old Aug 30, 2013 | 06:59 PM
rsmark86's Avatar
rsmark86
With the st170's won't the comp ratio be wrong in a silvertop? Or will it be like karlos's set up with 1.8mm frs gasket?
Old Aug 31, 2013 | 11:32 AM
Karlos G's Avatar
Karlos G
Balls Deep!
ST170 pistons are high pressure cast (like RST ones) so are a fair bit stronger than normal Zetec ones, the rods are sinter-forged.
Old Aug 31, 2013 | 05:53 PM
rsmark86's Avatar
rsmark86
So karlos, would they work in a silvertop with the same head gasket as you?
Would make a very cheap 300bhp engine if they did
Old Aug 31, 2013 | 06:06 PM
crazycage's Avatar
crazycage
yes they would
Old Aug 31, 2013 | 06:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I have no idea what the CR would be, physically yes it seems it would all fit but beyond that I don't know mate.
Seeing as the black top has the better head and the ST pistons and rods are in a black top bottom end it doesn't make any sense to retro fit them to a silver top does it?! lol
In this case James is trying to keep his silver top so he doesn't have to change any of his ancillary setup which is fair play.
Old Aug 31, 2013 | 09:49 PM
Turbo Zetec
Engine Machinist
Mahle Pressure cast pistons would be 84P (like the Focus RS), whereas the st170 pistons are 84L, making them normal cast
Old Aug 31, 2013 | 09:52 PM
studabear's Avatar
studabear
So what do you think is a safe limit for st170 pistons?
Old Aug 31, 2013 | 09:56 PM
Turbo Zetec
Engine Machinist
apparently over 300bhp, but until someone pushes them over their limit, we won't know
Old Aug 31, 2013 | 09:57 PM
rsmark86's Avatar
rsmark86
from what i read is at 9-0-1 mapped correctly they are upto 350bhp
but i guess 300bhp would be a safe limit
karlos for him it would work well then, but for anyone else they might aswell fit a blacktop.........
my gotech has the stuff to activate vvt already done so im thinking of building a st170 engine with forged pistons and rods and decent valve springs as a later swap when i get bored........
sitech says the vvt and turbo is awesome
Old Aug 31, 2013 | 10:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I stand corrected! lol Interesting then that they will take 350bhp.
Simon at Sitech pushed them over their limit, 355bhp.
Old Aug 31, 2013 | 10:28 PM
fordcozyjohn's Avatar
fordcozyjohn
sorry to but in but can any one help me will the cams from a fista 1.6 zetec s fit my gf 1.6 zetec 04 focus ?
Old Aug 31, 2013 | 10:30 PM
studabear's Avatar
studabear
probably, but best checking with fords
Old Aug 31, 2013 | 10:31 PM
fordcozyjohn
ok thanks m8
Old Sep 1, 2013 | 05:40 AM
rsmark86's Avatar
rsmark86
i dont think so bud, isnt the 04 focus a normal zetec and the zetec s is a zetec se (yamaha engine) totally different if so
Old Sep 1, 2013 | 06:32 AM
mp1's Avatar
mp1
I like him nice!
I'm glad somebody asked this as im looking at turboing an st 170 engine for my mk4 escort build!
Mmmm.the only question is over the vvti..to run or not to run??
Old Sep 1, 2013 | 07:39 AM
studabear's Avatar
studabear
do it, mines just made 247bhp @wheels, 14.5psi boost, no vvt tho
Old Sep 1, 2013 | 08:27 AM
rsmark86's Avatar
rsmark86
Gotech mfi pro and pro x, have a built in function to activate the VVT, and I think dta has full control over it
I say be different and keep it
Frs internals with decent valve springs and gaskets with frs plugs and should see good figures
There was a guy running 390bhp on a stock frs bottom end not long ago
Old Sep 1, 2013 | 11:29 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Lose the ST head all together, again after speaking with Simon @ Sitech he advised against using them as they warp at the first sign of heat making them unreliable when turbo'd.
Fit a black top head, 1.8mm FRS Head Gasket FINIS 1361410, ARP rod bolts and your good for 350bhp with the correct turbo etc.
Old Sep 1, 2013 | 05:48 PM
rsmark86's Avatar
rsmark86
Oh, I really wanted VVT
But Simon knows his stuff so best too Listen
Old Sep 1, 2013 | 06:49 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I did too, but when the voice of experience advises against it... you listen! lol
Old Sep 1, 2013 | 07:21 PM
rsmark86's Avatar
rsmark86
Yeh, he has the best experience with it so best too listen
Old Sep 1, 2013 | 07:28 PM
crazycage's Avatar
crazycage
We have no warped head problems with Ricks st170 turbo and my old one was fine too
Old Sep 1, 2013 | 08:12 PM
rsmark86's Avatar
rsmark86
I would only want 350bhp ish, and try and keep some response and have it rev well
Old Sep 1, 2013 | 08:39 PM
project rs's Avatar
project rs
so you going to use a 170 head on the next engine or blacktop, that is if you ever get your finger out again and build that bottom end you keep promising p.s 30ft of 40x40 box for the brace dimensions to follow
Old Sep 1, 2013 | 08:43 PM
crazycage's Avatar
crazycage
Blacktop for me
Old Jul 24, 2020 | 10:59 PM
Billybob1982's Avatar
Billybob1982
Default Rs pistons in blacktop st170 turbo
Would rs pistons fit the conrods on the st170 and would it be worth it doing a blacktop head St 170 block turbo
Old Jul 25, 2020 | 07:06 PM
Turbo Zetec
Engine Machinist
Focus rs pistons will not fit st170 rods unfortunately
jessie_rs
62
Aug 6, 2019 09:27 PM
locum8
Sep 14, 2015 08:45 PM
little bram
Sep 10, 2015 10:45 PM
ajamesc
Sep 8, 2015 06:51 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
