Cleaning metal filings out of an intercooler????
I've had a load of work done on my chargecooler and there's loads of metal filings inside it now.
I cut the end tanks off and grinder off the faces so they were clean/flat to have new ends welded on and also drilled a bleed hole in the water circuit.
Now I need to clean it out to refit it.
I tried washing it with parts wash, nothing. I've got a cleaner that goes on an airline and let's you fill it with brake fluid cleaner then fire air through it at 3bar, that helped but wasn't enough.
What can I do to clean it all out?
I've spoken to a local firm that make intercoolers/radiators....
They will steam clean it for me but don't guarantee to get it all out. And it's £60.
What else can I do?
Any others ways of cleaning it???
What else can I do?
The guy who welded it for me said the same. And he makes them.
it's just a case of keep doing it until nothing more comes out
If its just a charge cooler could you maybe fit a little in line filter for a bit in order to catch any debris maybe an old style fuel filter. ( little clear plastic one with yellow filter)
THROW IT AWAY is my advice !!!
I done exactly the same with my old xr2 turbo grs cooler, flushed it till it was like new then when mapping it to 2.5bar boost it blew a load of swarf into the inlet and into the head and fucked the whole engine costing me 3k+
That why I recently sold my pro alloy cooler and had a custom 1 made rather than cutting it risking swarf etc getting into the core, most expensive mistake I've made with my cars! Never again
Spend some time letting it soak in a decent detergent that will losen the swarf, then fill it with water n slop it around abit, id do this 3/4 times then let a hose run thru it whilst moving it about.
Ultimately its a big risk using it, so i'd be anal with cleaning it out.
