Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Replacing the fuel pump
Old Aug 27, 2013 | 11:07 PM
purplefocus's Avatar
purplefocus
Default Replacing the fuel pump
Hi,
New here but hopefully someone will be kind enoguh to help out.
Been reading all over the place and not getting much help or getting contradiction on the next last thing I read regarding changing this over.
I have a w reg 1.8 zetec petrol and the pump is iffy eg sometimes no priming sound then it wont start ( last time 200 miles away from home )
I've carefully cut an access panel out and can see the pump fine and have a new one and new o ring to seal it.
Question is how exactly do you get the fuel pipes out? I can find any pics anywhere. Some suggest removing the entire red lock by pressing down the tabs ( I think this is incorrect? ) others say push the red locking part forward towards pump and then pull the pipe out whilst leaving the red part in place. ( Im guessing this IS correct? ) Whats on the web shows only a single fuel pipe at the top so gueesing US pumps are different.
Secondly. I read pulling fuse 12 out then starting car to depressurize, others say start the car first then pull it out? Whats the preferred method?
Sorry its a long ( first ) post but I want ot replace the pump tomorrow night.
Cheers.
Old Aug 27, 2013 | 11:12 PM
GVK.'s Avatar
GVK.
2nd method is the way with those fuel pipe clips, it is possible to do them the other way but you need 3 hands or some weird looking pliers.
Just disconnect the pump electrical connector and run it till it stops (it'll be a few seconds at the most)
Old Aug 27, 2013 | 11:33 PM
purplefocus
Thanks for confirm.
If you don't mind. As far as I know the pump is just twist acw and remove?
Old Aug 27, 2013 | 11:48 PM
GVK.'s Avatar
GVK.
Yep, like a bulb
Just have to feed the pipes in to get the top back on.
Grease the threaded ring and make sure it goes on straight, quite easy to cross-thread 'em.
Old Aug 28, 2013 | 05:25 AM
purplefocus
Sorry I was referring to the actual pump that goes inside tank not the big ring that sits on top of tank.
Old Aug 28, 2013 | 05:28 AM
purplefocus
Sorry just reread your reply and you did answer my question....
Old Sep 3, 2013 | 10:40 PM
purplefocus
Did it is the end and took about 30 mins minus the cutting.
Anyway filmed the job being done - hope this helps someone out
Old Sep 3, 2013 | 10:47 PM
GVK.'s Avatar
GVK.
Ford missed a trick with no access panel to remove the fuel pump with tank in situ.
Even a mk2 Golf has one released in 1983/4 !!
cossie09
Sep 14, 2015 04:21 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
muffster
Aug 12, 2015 08:14 PM
