Brake pipe flaring
Old Aug 26, 2013 | 07:53 PM
grass racer's Avatar
grass racer
Default Brake pipe flaring
Hi guys,
Having to make new copper brake lines on my mk2 xr2 just on the rears from flexi hose to wheel cylinder.
I've bought a brake pipe flaring kit I'm awaiting the delivery.
I'm just wondering what type of flare do I use on the male and female connectors?
Single flare, double flare, bubble flare etc lol
Thanks
Old Aug 26, 2013 | 07:59 PM
GVK.'s Avatar
GVK.
Without sounding clever,easiest way is, you copy the old pipes.
Old Aug 26, 2013 | 08:12 PM
cossiejay's Avatar
cossiejay
that is what I do when making new pipes
Old Aug 26, 2013 | 08:16 PM
GVK.'s Avatar
GVK.
Best tip is, if you've never made brake pipes before is to always put the nut on the pipe BEFORE you flare it.
Old Aug 26, 2013 | 09:33 PM
stevieturbo's Avatar
stevieturbo
C**t
And read the instructions on the flare tool
Old Aug 26, 2013 | 10:51 PM
jamie's's Avatar
jamie's
take note of this
i've been a mechanic 17 years and still do this sometimes
Old Aug 26, 2013 | 11:16 PM
GVK.'s Avatar
GVK.
Very easily done, always allow for a bit of brain fade when making the lengths of the pipe.
Old Aug 26, 2013 | 11:46 PM
focusv8's Avatar
focusv8
And always make the longest pipe first, then if you get it wrong length or miss the nut off, you can cut it down and use the pipe for a shorter piece
Old Aug 27, 2013 | 05:18 AM
I sometimes put a bit of tape on to stop the nut part going all the way down the pipe.
Old Aug 27, 2013 | 02:40 PM
grass racer
Cheers for the info fellas I've found out I need a single flare for the male connection and a double flare for the female connection
Old Aug 27, 2013 | 02:59 PM
natehall's Avatar
natehall
one other big tip - depending on the kit that you get.. if running long pipes run the length first, clipping it in along the way...
Then you dont have it to long and have a bit on the exhaust pipe like a friends car did after coming out of a garage...
Old Aug 27, 2013 | 06:01 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I still make this mistake every now and then!! Made a pukka pipe for my Cossie and it was spot on, flared the ends and forgot to put the fittings on!!
Made another one and it was shit!!
Old Aug 27, 2013 | 06:25 PM
GVK.'s Avatar
GVK.
I've done the same, bent it to the right shape, looked decent.
NO NUTS... C U N T !!!!!!
Old Aug 27, 2013 | 07:54 PM
natehall's Avatar
natehall
or nuts the wrong way round is another popular screw up
stephenb4506
33
Oct 2, 2015 06:25 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
