hello,can anyone tell me where the fuel pump relay is located?and what colour is it?my rs died the other day and after a couple of minutes detective work i found that the fuel pump wasnt powering up.i ran a wire from the battery to the positive terminal on the pump and it worked.so i am presuming its the relay as all the relevant fuses were ok.
There's a number of relays under the dash, the fuel pump relay is larger than the others a d pink/purple in colour. Never come across a grey fuel pump relay.
Not the beat picture but the one on the left
pump relay is on the left of the pic, just a quickie, what are the 2 black/red wires going to?
