AP 6 POT QUESTION
Old Mar 19, 2005 | 09:17 PM
STUCOS's Avatar
STUCOS
Default AP 6 POT QUESTION
Fitted a set of 355 disc,s and ap 6 pots to my mates 4x4 saff,bolted on his brand new 18" mo,s and guess what,the caliper fouls the spokes on the mo,s.has any body had this problem,brake kit came off an ecos which had 18" rondells
cheeRS stu
Old Mar 19, 2005 | 09:27 PM
DAN P's Avatar
DAN P
i was told there was a prob with the new mo s they would not fit the big brakes could be wrong though ask mr hadland he would no might be off set
Old Mar 19, 2005 | 09:29 PM
STUCOS's Avatar
STUCOS
dan wheels are old 6 spoke design,and they came from martoooooon so should be ok,think a 4 mm spacer will be the answer
Old Mar 19, 2005 | 09:35 PM
DAN P's Avatar
DAN P
ah sorry m8 thought it was the new ones i dont no then hehe spacers should sort it
Old Mar 19, 2005 | 10:38 PM
NUTS RuS's Avatar
NUTS RuS
A mate had a similar problem on his road car scooby. He didn't want to run spacers so his only other option was new wheels.
His wife wasn't best pleased to say the least
Old Mar 19, 2005 | 11:58 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
abviously not a gd kit
Old Mar 20, 2005 | 06:40 AM
marco polo's Avatar
marco polo
Hi mate
Did you send the wheel of aswell when you was getting your brackets and bells made ???
if you do use a spacer make sure you use longer studs
hope this helps
marco
Old Mar 20, 2005 | 07:56 AM
STUCOS's Avatar
STUCOS
no marco,wheels where bought new before the brakes,as said they cam from martoooon and correct et for saff,brakes where sh from cam off of here,surrised they cleared rondell,s and not mo,s
rsgus thats the ones,by the way folks the bells are flat
cheeRS stu
Old Mar 20, 2005 | 09:10 AM
Chris Honeywell's Avatar
Chris Honeywell
mmm
I had to fit 5 mm spacers for my 4 pots
and that was with the Avez As`
i bought a proper kit with longer studs etc
Old Mar 20, 2005 | 11:08 AM
Rs Gus's Avatar
Rs Gus
rondells on cams car was a et20 with a 3mm spacer on also mine had NO spacers on and was 362x32mm not the 28mm ones u have my wheels was et 35
Old Mar 20, 2005 | 11:10 AM
Rs Gus's Avatar
Rs Gus
see this piccy had no spacers on
Old Mar 20, 2005 | 11:15 AM
Porkie's Avatar
Porkie
and there is your answer...
Old Mar 20, 2005 | 11:51 AM
markk's Avatar
markk
whats the big deal about people not wanting to run spacers ??
DazC's Avatar
DazC
The Escort runs totally different offsets to the Sapph so this is your problem...
My Dad has an AP 6 pot set up using 356 x 32mm Discs sat here and they fit just with ET37 wheels.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
