Focus RS mk1 Aftermarket Water Temp Gauge
Old Aug 21, 2013 | 01:29 PM
RS Bowk's Avatar
RS Bowk
Default Focus RS mk1 Aftermarket Water Temp Gauge
What have you guys done? Ive got a mate who is not happy with there not being a water temp gauge in his focus as standard.
Anybody got any pics of alternatives to standard?
Old Aug 21, 2013 | 01:33 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Sorry bout the small pics (iPhone)
Put something like this in line, and a sender screws in the top
Old Aug 21, 2013 | 01:36 PM
RS Bowk's Avatar
RS Bowk
Im interested to see what you guys have done inside the car.
Old Aug 21, 2013 | 02:02 PM
JamboRS's Avatar
JamboRS
focus rs 1672
could go for a scangauge like this
ive got the plx devices gauge which reads water and charge temps from obd and has the afr module
Old Aug 21, 2013 | 09:07 PM
Shings's Avatar
Shings
Don't have one. 18k miles in the 18 months, between 60 and 600 miles a week depending on where I'm working. No problems.
Old Aug 22, 2013 | 12:57 PM
RS Bowk's Avatar
RS Bowk
Any others?
Old Aug 22, 2013 | 04:38 PM
RSargie's Avatar
RSargie
Being a more modern ford, it has a fail safe cooling system. Where when the engine management detects an over heating issue. It illuminates a warning light. Engages limp mode and will only let you drive for a limited time. Then the engine will shut Down to save a failure.
Much more important for this type of car is inlet charge air temp because there is no fail safe for increased inlet temp . I.e charge cooler pump failure. Which can cause detonation .
Old Aug 22, 2013 | 05:09 PM
GVK.'s Avatar
GVK.
Scangauge idea is the best, there's a German site that sells something similar too which is configurable for any parameters from the OBD socket.
http://www.obd2-shop.eu/ultragaugeemv12-p-287.html
Old Aug 22, 2013 | 09:37 PM
rhys78's Avatar
rhys78
first thing i bought for both my RS's was a scanguage. better to be safe than sorry
Old Sep 10, 2013 | 04:46 PM
Simmo's Avatar
Simmo
I've got one of these plumbed into the top hose and a Scangauge too, would say the Scangauge is good enough on its own but the gauge was on the car when I bought it
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
Ben26
Sep 3, 2015 07:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Sep 3, 2015 10:49 AM
