Another gear linkage thread
Getting my 3i back next week and after reading all the threads i understand that upgrading to a puma linkage is much better
Does anyone have any tips, is it easy to do?
Is it defiantly worth doing?
Any help would be appreciated
easy job , av done this upgrade on my s1 , took bout 2hrs start 2 finish , u will need 2 drill 2 holes 2 mount the rubber holder of the puma linkage on the shell, and trim the width down also 2 fit in the shell's tunnel , apart from that it was a doddle ....gear selection is now similar 2 a quick shift as the throw is a lot less than standard linkage ....
as a further upgrade you can replace the rubber bushes on the lever and rods with solid bearings , this will remove any movement but you will get a bit of vibration through the lever
any bearing specialist will have something that will fit
The Youth.
Sep 30, 2015 09:59 PM
