Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Rev Counter feed for mk5
Old Aug 20, 2013 | 10:17 PM
f2tmg's Avatar
f2tmg
Default Rev Counter feed for mk5
Hi all
Fitted gauges with a rev counter to a 1.3, everything works except the rev counter checked the plug and the feed wire is missing, where do i take the feed from and is there a good way of adding the pin into the plug
Many Thanks
Old Oct 30, 2013 | 09:59 AM
leejst's Avatar
leejst
I would like to do the same to my mk5 1.3 I take it u only had the clocks with the speedo and fuel guage before? What model were the clocks from? Was ithe plugs the same for the new clocks and did the temp guage work alright?
I'm guessing u would prob need to take a feed from the one of the pins on the ecu but not 100%sure?
Old Nov 2, 2013 | 06:25 PM
Mk4 Rick's Avatar
Mk4 Rick
take a feed from the multi plug on the coil pack
rex647
Mar 6, 2022 06:20 AM
massivewangers
30
Oct 1, 2015 07:40 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
