Engine Help!!
Old Aug 19, 2013 | 05:12 PM
waynefrst235's Avatar
waynefrst235
Default Engine Help!!
Hi folks, got a couple questions I hope someone can help with.
Dropped a knackered engine off to be stripped and rebuilt last week and got the dreaded phonecall today saying the crank cannot be saved
I think I have sourced a crank and everything else is ok apart from the rod on cylinder 4.
Looks like I will have to buy a complete set so what would people recommend??
It won't be chasing big power, stage 3 on a t34 is as far as it will be going.
As said everything else is fine....pistons, bores, head etc, just need some advice on rods to go with the crank.
Thanks in advance
Old Aug 19, 2013 | 05:27 PM
LHD220Turbo's Avatar
LHD220Turbo
standard rods are great in a yb, they are good for circa 600hp so no need to change.
Old Aug 19, 2013 | 05:35 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
If you want to get uprated then PEC but i would stick with standard
Old Aug 19, 2013 | 06:45 PM
waynefrst235
Cheers, standard it is then.
Any idea where stocks them? Can find one set on ebay and that's it
Old Aug 19, 2013 | 07:06 PM
LHD220Turbo
try burton power maybe
Old Aug 19, 2013 | 07:21 PM
waynefrst235
Burton only list Farndon rods for them nowadays
Old Aug 19, 2013 | 09:59 PM
markk's Avatar
markk
I have several rods I will sell singularly if required.
I also have a reground crank too
Old Aug 19, 2013 | 10:30 PM
waynefrst235
Pm'd markk
Old Aug 19, 2013 | 10:36 PM
rsmark86's Avatar
rsmark86
second hand bud, just get everything checked and balanced beforehand
Old Aug 19, 2013 | 10:42 PM
waynefrst235
Yep I don't mind using used parts as long as they are good. The engine is all stripped and will be rebuilt by a pro so no worries there
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
