removing my mk4 crank pulley
Old Aug 18, 2013 | 08:13 AM
davecrook1's Avatar
davecrook1
Default removing my mk4 crank pulley
I want to change my waterpump and cam belt.. Removed pulley bolt but can't remove the pulley... Any ideas
Old Aug 18, 2013 | 08:20 AM
studabear's Avatar
studabear
get a screwdriver or small lever on either side of it to try and release it. You might be able to get a longer lever/pry bar in to give it a gentle tap.
Old Aug 18, 2013 | 08:34 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Heat, slide hammer, lever bar, bearing puller, 2 wooden wedges either side
Old Aug 18, 2013 | 08:43 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
They are gits to remove
Soak it in wd and leave it for half hour then try again
If you have a good spare you could grab it with some molegrips then hit those but you could damage the pulley
DixieTheKid
11
Jun 6, 2020 11:20 AM
bassboy
Sep 10, 2015 08:54 PM
BRAM
Sep 8, 2015 07:11 AM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
