Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
2000 ford focus mk1 central locking problem
Old Aug 17, 2013 | 01:18 PM
Roy89's Avatar
Roy89
Unhappy 2000 ford focus mk1 central locking problem
Hi yesterday I went to lock the car and it just won't lock just clicks when you try and lock with fob and when you try by pressing button in on the inside or when you put key in lock and turn its just unlocks straight after any help appreciated thanks Roy
Old Aug 17, 2013 | 02:39 PM
Roy89's Avatar
Roy89
Tried unplugging for 5 mins from drivers kick panel then plugging bk I. And tried unplugging each door separately still no luck
Old Aug 17, 2013 | 03:44 PM
stevos's Avatar
stevos
My frs does this when its really cold. Could be one of the door switches that brings on your interior light or boot switch. Worth checking these first
Old Aug 17, 2013 | 03:57 PM
GVK.'s Avatar
GVK.
Sounds like one of the motors is cycling, disconnect each door multi plug in turn if you can get to the plugs and try it then.
Old Aug 17, 2013 | 04:26 PM
220tel's Avatar
220tel
try locking it with the passenger door
its quite common on the mk1 focus for the central locking to play up
Old Aug 17, 2013 | 06:03 PM
Roy89's Avatar
Roy89
Hi thanks for all replys I have tried to disconnect the wires at the bottom inside of each door with no result and have tried four sensors on the doors all seem ok press them 4 5 times and I detractors flash but not sure on the location of the boot one and does the same on passenger door as it does the drivers thanks again for replys any advice will be tried kind regards
Old Aug 17, 2013 | 06:24 PM
stevos's Avatar
stevos
Not 100% on the boot one but is there one on the bonnet latch also.
Old Aug 17, 2013 | 06:31 PM
GVK.'s Avatar
GVK.
Bonnet lock isn't connected to the central locking, only has an ajar switch for the alarm.
Old Aug 17, 2013 | 06:32 PM
Roy89's Avatar
Roy89
Thanks for reply will try and find on on bonnet the night thanks again
Roy89's Avatar
Roy89
Aw ok thanks
Old Aug 17, 2013 | 07:17 PM
stevos's Avatar
stevos
Wasn't 100% mate too be honest. Good luck mate
Old Aug 17, 2013 | 07:23 PM
Roy89's Avatar
Roy89
That's fine mate any advice appreciated thanks hopefully get it sorted
Old Aug 17, 2013 | 07:26 PM
I had a problem on my 2001 mondeo central locking ,got a new drivers unit from the scrappy Ł20 ,fitted it all good ,may be worth a shot
Old Aug 17, 2013 | 07:29 PM
220tel's Avatar
220tel
open the bonnet and keep tapping the bonnet ajar switch until it makes a beep
then open each door in turn and you will hear a beep
lock the drivers door then unlock
lock the passenger door and unlock
one of these will make a different sound this is the one that is playing up
Old Aug 17, 2013 | 08:15 PM
Roy89's Avatar
Roy89
Thanks everyone will try that tel thanks and I would like to find out what one has problem first twin cheap for the advice tho I am sure it will all come in handy
Old Aug 17, 2013 | 08:45 PM
Roy89's Avatar
Roy89
Hi does the bonnet thing look like pin near the lock if so I pressed it freed it with wd40 then press it again quite stiff but wen pushed no noise From it at all no beeps or chimes can you help thanks again
Old Aug 18, 2013 | 03:54 PM
Roy89's Avatar
Roy89
Hi thanks all for replys has anyone got anymore ideas carnt get to beep at bonnet so other things to try please anyone
Old Aug 18, 2013 | 04:07 PM
GVK.'s Avatar
GVK.
That bonnet switch trick doesn't work on mk1 Focus to enter self-test mode.
tbh, your problem must be either a sticking latch or wiring fault going to one of the doors or tailgate
Have you tried checking the wiring where it goes into the tailgate, in case it's chafed and wires touching each other?
Old Aug 18, 2013 | 04:47 PM
Roy89's Avatar
Roy89
Hi thanks for reply is that the wireing at the top of the trunk its very strange as if I lock manually they all unlock with.the fob thanks again
Old Aug 19, 2013 | 08:28 PM
Roy89's Avatar
Roy89
Any more suggestions people all welcome thanks again
Old Aug 27, 2013 | 11:12 PM
purplefocus's Avatar
purplefocus
Given up trying to suss the focus CL.
When it rains mine just open and lock at random.
Sounds like doors are not registering as closing properly possibly.
taylora1409
Aug 12, 2015 12:06 PM
hazbaz1984
Jul 30, 2015 05:15 PM
