Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
which axle/diff in mk2
Old May 4, 2004 | 09:51 AM
bazza's Avatar
bazza
Default which axle/diff in mk2
hi all
i have just baught my self my first old school ford
unfinnished project want to know which axle to fit or diff
the shell was a 1.3 but re shell on rs2000 v v v sollid car has had alot of
work done at retro motorsport bulkhead cut back 5 inch large gearbox tunnel,large prop tunnel,large diff tun,engine wise it has got vauxhall 2.0
16v xe ported an pollished head lightened an balenced flywheel, runnin twin 48's ,type 9 box with taller 1st gear rs 2000 single piece prop.
im just wondering what you chaps think the way to go is on the axle/diff side of things???
thanks
barry
Old May 17, 2004 | 02:28 PM
fatboyz's Avatar
fatboyz
hi there we fitted a capri 2.8i special axle to the mk 2 we are building as its a cheap way of getting a lsd good for atleast 250 - 300 bhp and if you are arching the motor it gives it a wider track
Old May 21, 2004 | 09:46 AM
Markb_s1's Avatar
Markb_s1
Atlas IMO as said above - form a 2.8i capri - comes with a slipper and good n strong. you'll need to get it shortened if you want to use standard arches though.
timsrs
Nov 13, 2018 11:48 AM
89barto89
Oct 4, 2015 06:59 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
Sp3no
Sep 27, 2015 07:23 PM
