No Spark Help!!!
Old Aug 10, 2013 | 01:51 AM
tejy's Avatar
tejy
Default No Spark Help!!!
I'm not getting any spark for some reason after sticking my new bottom end in..
I've run a wire from battery to positive from the group a coil
Got a new dizzy cap
New distributor
Everything is wired up as it should be
Firing order is correct
New spark plugs
Fuelling is fine
Read up on previous threads and just had no luck with any of it..
Engine is cranking as it should be but just not getting any spark!!!
Really need to get this sorted ASAP otherwise I'm missing ford fair.. again
Anyone got any ideas because after building the whole engine back up it still doesnt want to start
Old Aug 10, 2013 | 06:03 AM
Joycey85's Avatar
Joycey85
The 2 green wires from the coil?
Old Aug 10, 2013 | 12:26 PM
tejy's Avatar
tejy
One of the green wires is showing 9volts, the other is showing 1 volt.
Old Aug 11, 2013 | 04:08 AM
tejy's Avatar
tejy
Turned out to be a dodgey distributor!
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
