Which ib5 box?
Old Aug 7, 2013 | 06:36 PM
Jimbo-m-89's Avatar
Jimbo-m-89
Default Which ib5 box?
Hi, I want to change my gearbox over to an ib5 gearbox... But nobody I ever ask seems to know exactly which one I need?.. I.e. from which car?
All I know is that It needs to be a front starter type... And was told to go look around a scrappy for one haha.
So if I was to ring a gearbox company and ask for a gearbox, which exact car would I need to tell them that I have?
Thanks, James
Old Aug 7, 2013 | 07:04 PM
GVK.'s Avatar
GVK.
Seen a Ka one mentioned on here, which Ka I don't know.
Do a Google search
search Ka,ib5,passion ford
Some forum searches don't let you search for 2 or 3 letter words.
Old Aug 7, 2013 | 07:07 PM
GVK.'s Avatar
GVK.
https://passionford.com/forum/ford-e...at-itself.html
Old Aug 7, 2013 | 07:19 PM
Chopshop85's Avatar
Chopshop85
MK5/6 escort diesel gearbox.
Ka 1.3 gearbox
Escort rs turbo LSD
Use the diesel final drive with the ka gearset and your RST's lsd.
Be like a standard box (give or take a few mph in each gear) but stronger.
I'd recommend getting a puma gear linkage to go with it.
Old Aug 8, 2013 | 09:25 AM
rsmark86's Avatar
rsmark86
Ka 1.3 gearbox
Escort rs turbo LSD
Just what I'm doing
P.s if you have a zetec instead of a cvh a rear starter ib5 is a third of the price of a front starter
Old Aug 8, 2013 | 12:00 PM
Chopshop85's Avatar
Chopshop85
You can also use a puma 1.7 final drive with the Ka gear set if you want identical ratio's to the Erst bc box. However, the Erst LSD will need modifying.
Old Aug 8, 2013 | 04:19 PM
rsmark86's Avatar
rsmark86
For me I'm not fussed by the ratios to much, just want to be able to use it
But if you don't have a lot of power I wouldn't want any longer than a rst
Old Aug 8, 2013 | 04:35 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Dnt waste your time or money with the ka box just a mk6 escort diesel no turbo box with series 2 LSD job done
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
