E38 brembos
Old Aug 3, 2013 | 02:21 PM
cossie891's Avatar
cossie891
Default E38 brembos
Has any one fitted these
Old Aug 3, 2013 | 02:55 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
yup, i fitted some to my xr4x4 turbo.
Old Aug 3, 2013 | 02:58 PM
cossie891's Avatar
cossie891
Sound do you have any pics and do you know if they stick out any further than cosworth 2wd calipers?
Reason I ask is I am about to order some but want to make sure they will fit as I can't return them if they are marked up
Old Aug 4, 2013 | 12:30 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
i think they will stick out further, you need 17" wheels.
Old Aug 4, 2013 | 12:44 PM
cossie891's Avatar
cossie891
Any chance of a few pics and could I be really cheeky and ask how wide the calipers are please
Old Aug 4, 2013 | 08:46 PM
Marc sierra's Avatar
Marc sierra
I measured one and they stick out about 6.0 cm from the disc surface. Also be aware the FRS discs are thicker (28mm) than the standard Cosworth discs (24mm) and also have a lower height (52.7mm) than Cosworth discs (55.1mm) which makes the caliper stick out even further.
So I think you should have at least 6.7 cm room from the standard disc surface (6.0 cm + 0.4 cm thicker disc + 0.24 cm less heigt). And of course a few mm clearance.
Old Aug 4, 2013 | 08:50 PM
coswurv's Avatar
coswurv
If running 2wd set up, use evo brembo's, focus rs mk1 front discs, all you need is a flat bracket, its so easy to do mate, good stopping power for little money, its on my saph resto thread some where with pics and measurements.
Old Aug 4, 2013 | 09:01 PM
cossie891's Avatar
cossie891
Marc sierra thanks for that I have forwarded that to the company selling the wheels
Coswurv what calipers are they? How much are they
Old Aug 4, 2013 | 09:12 PM
cossie891's Avatar
cossie891
Will they fit behind 17s
My std calipers are about 3mm away from the back edge of my wheels but need bigger brakes lol
Old Aug 4, 2013 | 09:38 PM
BIL N KEL's Avatar
BIL N KEL
Evo 5 6 7 8 9 all have the same front calipers I believe as looked into this conversion when upgrading. Going this route will require custom brake lines/hoses though
Old Aug 4, 2013 | 09:42 PM
cossie891's Avatar
cossie891
How easy is to do this conversion
Old Aug 5, 2013 | 07:37 AM
coswurv's Avatar
coswurv
It's easy mate, you can make your own hoses up by buying the parts from www.raceparts.co.uk focus rs mk 1 discs, Evo calipers and pads etc, basically you need to grind a tiny bit off the caliper in between the mounting lugs to let the brembo sit closer to the 2wd hub, then it's basically a straight piece of ally block to elongate the hubs mounting holes, drill 2 holes to bolt ally block to hub, then two holes further out to mount the caliper.
Here you go, page 6
https://passionford.com/forum/restor...deja-vu-6.html
Old Aug 5, 2013 | 07:49 AM
cossie891's Avatar
cossie891
Looks and sounds cool. Are the much wider than std cosworth calipers as the new wheels I have bought are very close to the std calipers
Old Aug 5, 2013 | 07:53 AM
coswurv's Avatar
coswurv
Yes they are wider, at the end of the day the wheels I ran were 17" momo arrows and they have no brake clearance at all, I used 3mm "I think" spacers to miss the brembos plus iirc I fitted 63mm studs to the front.
Old Aug 5, 2013 | 07:56 AM
cossie891's Avatar
cossie891
Ok can you remember the offset if them. I might try to find them
Old Aug 5, 2013 | 09:00 AM
coswurv's Avatar
coswurv
Offset of the momo arrows?, if so no mate I don't have the car anymore.
Old Aug 5, 2013 | 09:06 AM
cossie891's Avatar
cossie891
Oh bother lol
The brembos for the e38 still look a good buy and I can do it for around Ł400
Old Aug 5, 2013 | 09:31 AM
coswurv's Avatar
coswurv
Oh bother lol
I did mine for just under Ł300, but yeah what ever you wanna do.
Old Aug 5, 2013 | 09:55 AM
Harris.'s Avatar
Harris.
Oh bother lol
I just got the kit off ebay , from caprisport . Ł440 Posted but not yet fitted them, the brakes do look like new .
I have 17s et30 and hope the fit
Old Aug 11, 2013 | 11:17 AM
Harris.'s Avatar
Harris.
Kit is now all fitted but my brake pedal feels very soft . so may have to re bleed them as they don't feel safe atall , I have about 2 inch's on the pedal before anything happens .
Old Aug 11, 2013 | 11:25 AM
cossie891's Avatar
cossie891
Got any pics mate I am waiting for mine
Old Aug 11, 2013 | 11:27 AM
Harris.'s Avatar
Harris.
I will have to take some mate, they do look big behind the 17s and looks a very nice kit
Old Aug 11, 2013 | 01:22 PM
cossie891's Avatar
cossie891
Ah cool I can't wait
Old Aug 12, 2013 | 01:03 AM
ClevoCapri's Avatar
ClevoCapri
This is my e38caliper with caprisport adapters fitted.
Disk size.
Old Aug 12, 2013 | 02:57 AM
Harryh24's Avatar
Harryh24
I was looking at these kits and upgrading to bigger calipers, but was thinking sorely of you've got more pots, means more fluid is needed to pumped at a different pressure?
so would you not need to update the master cylinder?
Old Aug 12, 2013 | 06:12 AM
cossie891's Avatar
cossie891
Awesome thank you
Old Aug 12, 2013 | 09:17 AM
Marc sierra
The 2wd cossie uses 4 pistons of 40 mm diameter. I think the E38 uses 2 pistons of 40 mm and 2 pistons of 44 mm. The surface of the 40 mm piston is 1256 mm2, of the 44 mm piston it is 1520 mm2. So the 2wd cossie has a total surface of 2512 mm2 (only counting one row of pistons to be able to compare them with sliding calipers), and the E38 caliper has a total surface of 2776 mm2.
So the total surface is about 10% higher, which means 10% more fluid needs to be moved to get the same movement of the pistons. Since the difference is not that big the standard MC will be fine.
The pressure coming from the MC stays the same, so with the 10% bigger surface you also get a 10% bigger force. But the torque exerted to the hubs is also bigger due to the larger radius of the discs (about 17%).
Old Aug 12, 2013 | 10:10 AM
Harris.'s Avatar
Harris.
I couldn't take any of that in
All I know is they look good ,not sure if mine don't feel right as you have to bed them in don't you ?????
Old Aug 12, 2013 | 12:26 PM
Harris.'s Avatar
Harris.
So just been out in the car again, if you do order this kit get it WITHOUT the EBC RED STUFF PADS as when cold your arse will be in your mouth like mine just was , when joe fitted them he did warn me they were shit but I didn't think they would be that bad . Changing them this weekend !!!
Old Aug 12, 2013 | 12:36 PM
luke19790_3's Avatar
luke19790_3
did the standard hoses fit?
Old Aug 12, 2013 | 12:57 PM
Harris.'s Avatar
Harris.
You have to re shape them to fit . Im going back to forodo ds2500 pads as there excellent , but trying to work out which one's I need is a headache , just called demon tweeks and they said there's loads what will fit, but I need to take the pad out , draw round it and email it to them
Old Aug 12, 2013 | 01:06 PM
Marc sierra
Why would you need to do that? I suppose you should be able to order a set of pads for a BMW E38 735i, as that is where the calipers are from.
Old Aug 12, 2013 | 01:09 PM
ClevoCapri's Avatar
ClevoCapri
The pedal travel is barely noticeably longer. Still nice and hard when you need it to be!
The pads im using are Ferodo ds2500's, part number FCP1298H.
Old Aug 12, 2013 | 01:12 PM
Harris.'s Avatar
Harris.
Do you have the same kit then mate . Just done a search on that number and its came up FOCUS RS which will be wrong for my caliper .
I hate Soft pedal ,ive always preferred hard pedal .
Old Aug 12, 2013 | 01:19 PM
ClevoCapri's Avatar
ClevoCapri
I have the E38 brembo caliper with Mk1 RS Focus disks with the caprisport caliper adapter. I had the calipers so I didn't need to get them off caprisport. But they are the same that they supply.
I bled mine a couple of times and the pedal is perfect. I have done a few track days now and the brakes have no problems. Just fresh fluid before each outing and the pedal stays nice and firm!
Old Aug 12, 2013 | 01:27 PM
Harris.'s Avatar
Harris.
Ive just messaged caprisport to see if he knows the model number . If im unsure about something ill change it , im very unsure bout these pads
Old Aug 12, 2013 | 02:13 PM
ClevoCapri's Avatar
ClevoCapri
It took me awhile to find the Ferodo DS2500 pad part number. I couldn't find a listing for a ds2500 pad for the e38 caliper. But they list the cars that use the same pad as the 7 series so I searched for a ds2500 to fit a r33/r34 gtr and got that. They fit perfect.
The e38 brembo uses the same pads as r33/34 gtr's, a couple of Maserati's, 550 Ferrari's and a Fiat coupe!
Old Aug 12, 2013 | 05:14 PM
cossie891's Avatar
cossie891
Awesome stuff I can't wait now
Old Aug 12, 2013 | 05:22 PM
luke19790_3
No they are different to a fiat coupe. I know because I had set next to my mates e38 pads. The e38 are bigger
Old Aug 12, 2013 | 09:44 PM
Harris.'s Avatar
Harris.
:cr y:
