Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Best induction kit for a MK6? [OPINIONS]
Old Jul 30, 2013 | 10:18 PM
JamieLittwin's Avatar
JamieLittwin
Default Best induction kit for a MK6? [OPINIONS]
I've got a MK6 Fiesta 1.25, I know I won't really gain anything from an induction but anything is better than nothing with such a small engine.
Would anyone recommend a particular set up or brand? Or what do you have personally?
Any help or advice would be greatly appreciated.
Old Jul 31, 2013 | 07:31 AM
FiestaSTurbo's Avatar
FiestaSTurbo
K and N are a nice kit mate.
Old Jul 31, 2013 | 09:42 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Try and get one that is enclosed with a cold air feed or at least route some cold air from as low down as possible to it. As you say wont give it any noticable performance but the cold air wont hurt it and may make it slightly more resoonsive. Something like K&N Viper i think they were called
Old Aug 1, 2013 | 03:06 PM
gjh's Avatar
gjh
I like K&N, always do well in mag tests, just make sure it aint sucking in hot air, try and get some heat shielding around it and good cold air feed to make the most of it.
Old Aug 12, 2013 | 06:02 PM
JamieLittwin
Couldn't really seem to find anything on the viper thing apart from the car. I don't know whether I'd be better going for a kit or just a standard air filter to go in the existing box seeing that they don't have much to offer.
http://www.knfilters.co.uk/search/ap...a&engine=1.25L
Old Aug 12, 2013 | 06:06 PM
RichieST's Avatar
RichieST
If you want it to make the most power then fit a panel filter in the standard box, if you just want to make noise then fit an induction kit.
Old Aug 12, 2013 | 06:09 PM
JamieLittwin
Is there anything which would give me the best of both worlds? Or what would you personally recommend?
Old Sep 27, 2013 | 06:18 AM
jammerrs's Avatar
jammerrs
K&N panel filter with a drilled air box (drill on the UNFILTERED side of the box) then get a cold air feed running to it
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
