Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
ST225 Sensor on O/S Wishbone
Old Jul 22, 2013 | 09:55 PM
Bubble Meister's Avatar
Bubble Meister
Default ST225 Sensor on O/S Wishbone
My car has a linkage from the OS front wishbone. It links to a sensor. Can anyone tell me what this sensor is? The linkage is creaking like mad.
Is it a calibrated item? If I remove the linkage from the wishbone to exercise it, will I scramble the electronics (with or without the ignition on)??
Cheers folks,
BM
Old Jul 23, 2013 | 05:21 PM
locum8's Avatar
locum8
I'm think this is for the ESP if I'm not mistaken.
Just remove the bolt from the wishbone then give the balljoints a good spray of wd40 and work it up and down until it stops sqeeking then reattach.
Old Jul 23, 2013 | 05:38 PM
chris cdti's Avatar
chris cdti
The sensor on the wishbone is for the headlight auto adjust to keep it at the correct height. The osr has one also for the same.
ESP works off the wheel speed sensors.
Old Jul 23, 2013 | 05:40 PM
GVK.'s Avatar
GVK.
As above, it's for cars with Xenon lights, controls the self-levelling.
Old Jul 23, 2013 | 07:46 PM
locum8's Avatar
locum8
My mistake
Old Jul 23, 2013 | 08:11 PM
Bubble Meister
Excellent folks. Thank you very much. I assume that as long as i leave the ignition off i won't upset the calibration. Has anyone else got a creaky link?!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
