Solid or poly rear beam bushes
Old Jul 14, 2013 | 11:15 AM
RSCossieGaz's Avatar
RSCossieGaz
Default Solid or poly rear beam bushes
Whats better on the car solid beam bushes or poly beam bushes?
Whats the differences etc and whats better pls
Thanks in advance
Old Jul 14, 2013 | 09:30 PM
jamie's's Avatar
jamie's
poly's seem to waer out fast on the rear beam mounts
solid feel best for spirited driving and lasy forever and a day
standard prob give the nicest drive
Old Jul 15, 2013 | 05:31 PM
I heard you get a bot more vobration through the solid mounts.
Old Jul 15, 2013 | 05:36 PM
Caddyshack's Avatar
Caddyshack
Unless I was racing I would go standard, I have had 3 cars with solid and poly bushes and they all squeaked and clonked at some point, I greased them regularly but always went back to noise.
Old Jul 15, 2013 | 11:06 PM
xr_craig's Avatar
xr_craig
Mine is on solid mounts and I was very surprised at how good they were. Nowhere near as harsh as I expected. I'd choose them every time now.
Old Jul 16, 2013 | 08:02 AM
bull-turbo's Avatar
bull-turbo
I went for solid as there meant to feel a lot better an if there noisy there easy enough to change an I haven't drivin with them yet that's all
Old Jul 16, 2013 | 08:59 AM
fraser9764's Avatar
fraser9764
i would say a decent diff mount is more important than the beam mounts, as that is where 90% of the movement will come from
for road use i would probably say use poly all round, however, mine is on solid beam mounts and a solid supra diff mount, and it is far better than i was expecting, you do get some more noise and vibration but its not excessive.
Old Jul 16, 2013 | 10:24 AM
Fil's Avatar
Fil
ELASTIC BAND
poly diff mount and solid beam mounts on mine, cant say the noise and vibrations are that bad.
Old Jul 16, 2013 | 10:10 PM
RSCossieGaz
Im going solid beam mounts and poly bushes on mine now and will go uprated diff mount too.
Old Jul 19, 2013 | 10:45 PM
The Crocodile Hunter's Avatar
Just put solid beam mounts and an msd diff mount on mine, the difference over the old standard stuff is amazing (although it was all quite tired)
Vibration through the car is nowhere near as bad as I was expecting, I would recommend this set up everytime over poly mounts
Old Jul 19, 2013 | 10:50 PM
Assume you mean poly bush the front end of the car? And not the rear trailing arms? That's a move backwards over the standard bearing setup.
Old Jul 19, 2013 | 10:56 PM
cossiestu's Avatar
cossiestu
I assume solid beam mounts are easier to fit too?
Old Jul 19, 2013 | 11:04 PM
Yep, really easy!
Old Jul 21, 2013 | 02:11 PM
RSCossieGaz
Solid rear beam mounts arrived- next on list will be uprated diff mount.
Old Jul 21, 2013 | 02:13 PM
RSCossieGaz
Front end is poly bushed yeah and solid rear beam bushes have arrived too,next on list is diff mount.Also have polys for the rear trailing arms.
Old Jul 22, 2013 | 11:18 AM
viperz888's Avatar
viperz888
Can opened.
Worms everywhere.
Old Jul 22, 2013 | 12:12 PM
I fitted a rear diff mount and was very suprised at how good it is.I overtook a car on the way to work one morning and the car just handled so well.It didnt wallow about or roll.
Old Jul 22, 2013 | 01:08 PM
BIL N KEL's Avatar
BIL N KEL
Maybe that's what I need then! I've changed everything on the front (ball joints, bushes and rack) of my saff but it still wanders all over the road. When going round a corner it feels like the back try's to overtake the front and even though the suspension is quite low and hard I think it feels like it has a bit too much body roll
Old Jul 22, 2013 | 02:18 PM
Originally Posted by viperz888
Can opened.
Worms everywhere.
That made me chuckle
Old Jul 22, 2013 | 02:22 PM
Makes a big difference doesn't it!
I put the solid beam mounts at the same time as changing the diff mount and was amazed at the difference!
I might put some poly arm bushes in now to fuck it all up??
Old Jul 23, 2013 | 03:04 PM
BIL N KEL's Avatar
BIL N KEL
Lol yes bud replace them good old bearings with some crappy bushes hahaha
Just put my car on the ramp to check my diff mount and it has some play in it. Is it a good idea to solid mount the diff? It currently has standard beam mounts but I would like to change them in the near future to solid/poly
Thanks Billy
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
155lee
Oct 27, 2015 04:55 AM
