Are COSY and ANTI ecu's interchangable
Old Jul 11, 2013 | 01:14 PM
steelej's Avatar
steelej
Default Are COSY and ANTI ecu's interchangable
As per the title anyone know if you can put a COSY ecu into a car that has an ANTI ecu? Are they interchangable? Might have an issue with my ANTI ecu but don't want to spend money on a COSY one if it won't work.
Thanks.
John.
Old Jul 11, 2013 | 03:56 PM
rog's Avatar
rog
Not sure if it's me, but I haven't got the faintest idea what an ANTI ecu is....
Maybe that's why no one has replied, can you explain?
Old Jul 11, 2013 | 04:56 PM
steelej's Avatar
steelej
The small turbo cossie ecu's have a 4 letter code, the ones i know of are CARD, COSY and ANTI, i believe they're just software updates but i don't want to spend 200 quid on a COSY coded ECU if it won't work with my car
John.
Old Jul 11, 2013 | 05:01 PM
jamie's's Avatar
jamie's
eeciv ecu's are interchangable i'm sure
i have swapped them in the past and never had any probs, unless i've just been lucky
Old Jul 11, 2013 | 05:22 PM
steelej's Avatar
steelej
Hi Jamie,
You've definitely swapped different ones, they've had the different codes on the ecu sticker?
Just double checking before i spend the cash
John.
Old Jul 11, 2013 | 08:10 PM
ELFRANCO's Avatar
ELFRANCO
I think the later ecu's on the small turbo's are coded to the key?
Old Jul 11, 2013 | 09:56 PM
steelej's Avatar
steelej
I was told the pats(passive anti theft system) is a separate system and not in the ecu.
John.
Old Jul 12, 2013 | 12:58 PM
ELFRANCO's Avatar
ELFRANCO
NO John, there linked, i have had to get the ecu an the key matched before on one's
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rex647
Mar 6, 2022 06:20 AM
griffo69
Oct 4, 2015 11:58 AM
Fezman1
Oct 2, 2015 01:22 PM
dms04
Sep 11, 2015 01:57 PM
