ST Escort cosworth overboosting
Old Jul 5, 2013 | 06:53 PM
steelej's Avatar
steelej
Default ST Escort cosworth overboosting
Hi Guys,
Been having a number of little issues with my Escos and latest one is with boost. On the small turbo the boost pegs at the end of the solid rectangle on the boost gauge until you go full throttle and you get 1.3 bar overboost for 7 seconds. My car was getting some work done recently and today after collection when holding the accelerator about half way the boost just continues to build and goes into the overboost section, it'll actually go into the red if you keep going but i wanted to avoid that. Any ideas what could be causing it to overboot and not stop at the end of the rectangle where it should?
Thanks.
John.
Old Jul 6, 2013 | 08:55 PM
steelej's Avatar
steelej
Ok back to this one, today i stripped all of the boost and vacuum pipes and checked for leaks, no leaks, i tried a friends AMAL valve, i then put on a new wastegate actuator and none of it has made any difference, it still overboosts but if i unplug the AMAL valve then i just get wastegate pressure. I'm really stumped on this, is there anything on the inlet side i can check, any sensors, pipes etc? Or could i just have been unlucky and my friends amal vale is goosed too, his car is modified so he expects the kind of boost i'm getting but it was a standard valve.
John
Old Jul 8, 2013 | 06:55 AM
midnight_man's Avatar
midnight_man
Check again all pipes about turbo for leaks,,,specially "T" pieces in system... I had same problem. You can easyly check you amal valve for working, unplug one side of pipe...connect 12V to amal valve (from battery) and make some pressure to pipe. You can test it if its working. (I am guessing that amal valve will be ok)
What chip you have in car? What ECU and what config of engine? Turbo, injectors...etc. Do you have vacuum on idle (on turbo pressure gauge)? When you "fast - softly" pull the accelerator pressure gauge must jump up to 0 bar for second. (If you have leaks, it will not jump to 0 bar, ).
Finally when there is a leak in the system turbo is charging pressure for a long time... car is little bit "lazy" up to 2500 - 3000 rpm.
Old Jul 8, 2013 | 11:41 AM
steelej's Avatar
steelej
Thanks Midnight_man,
So car is completely standard small turbo, no modifications at all, so standard chip injectors etc. if i unplug power to the amal valve i do just get wastegate pressure with no overboosting. The amal valve seems to be opening because when plugged in pressure is being bled from it to increase boost but it's either not being told to close or not getting the signal to close or somethng else elsewhere in the system but i'm pretty stumped now as when valve unplugged no overboost but with valve plugged in overboost.
Have got vacuum on idle, needle right at bottom of guage and boost does rise to 0 when pressing accelerator and have not noticed the car feeling lazy.
Any other ideas, any other sensors i can check?
John.
Old Jul 8, 2013 | 11:47 AM
midnight_man
Led diagnostic say something? Have you got a spare MAP sensor 2,5 Bar for your car to test change?
Orange light on cosworth clock is ON? (on engine idle) - it signals an internal fault in ECU.
Old Jul 8, 2013 | 09:18 PM
steelej's Avatar
steelej
Hi Midnight man,
Don't have a spare MAP sensor but sure i could borrow one havent noticed any lights on the clock but i'll check, can an OBDII reader read the ecu codes or is there something special required?
Thanks for all the help so far
John.
Old Jul 8, 2013 | 09:32 PM
midnight_man
http://www.bigturbo.co.uk/
But you have small turbo with ford EEC IV ECU I dont know if led diagnostic will work
but you will see orange light on cosworth clock if there is any fault in ECU... Try to change MAP sensor for sure ....and will see.
Old Jul 13, 2013 | 03:34 PM
steelej's Avatar
steelej
Top marks to midnight man, the MAP sensor was the problem. Swapped it with a friends and car working fine. New sensor now ordered
Had bought a code reader and code 126 was logged which is MAP voltage above spec, so looks like ecu wasn't getting correct info from the MAP sensor and didn't know what to do with the boost.
Thanks for the help midnight man.
John.
Old Jul 13, 2013 | 05:31 PM
midnight_man
Was orange light on cosworth clock ON?
Old Jul 13, 2013 | 10:17 PM
steelej's Avatar
steelej
No orange light, must be different in small turbo
John.
Old Jul 17, 2013 | 08:31 PM
Modest-UA's Avatar
Modest-UA
Hi Guys,
I also have a problem with the overboost but in my case the pressure didn`t go to "overboost" section on the gauge and stopped at 0,9-1,0 bar.
The fault code is 126 - MAP voltage above spec.
I`ve replaced MAP sensor 3 times, but without any result.
Any ideas?
Thanks in advance Max
Old Jul 19, 2013 | 11:41 PM
steelej's Avatar
steelej
Hi Max,
Same error as I was getting, have you changed the MAP sensor for a genuine ford one, i got a new sensor from Graham Goode and my problem remained, got a ford sensor from someone in the RS owners club and it fixed it. Don't ask me why that is
John.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
