Mk3-Mk4 roof skins (different or not) ?
Does anyone know if a Mk3 roof skin is the same as a Mk4, I'm looking to change my rusty sunroof tray but thinking of doing away with the sunroof and doing a skin change as my car has been converted to RWD using a Sierra floor and i've lost a bit of head room due to the seats sitting a little bit higher in the car, plus the rollcage front roof bar is in the way of the winding handle.
Ginger
Ginger
Cheers guys, picked one up on Thursday
. Looks a bit of a mission to take off though :-(
Ginger
Ginger
Yer defo, started to remove the old one yesterday, took 30mins to get the main section cut out, spent the next 5 hours trying to get the gutter rails and the front/rear window parts removed and still not finished :-( should get it all off today though.
Very time consuming
Ginger
Yeah its a slow job, we took 3 days in total doing my mates fiesta, that's taking the skin off a second hand roof, taking the one off the car and welding it back on the car, I did post pics on here ill see if I can find the thread, might be some help to you
3days is good going mate, it's taken me 4 days so far, but the new skin is on for a trial fit so a few more hours should see it finished.
Ginger
Ginger
Yer, on my own mate, just a hand to lift it on and off the car. All welded on now, just a bit of primer to go in from the inside so as to try and get it to run through between the gutter rail spot welds before I get some joint seal in along the gutters.
Ginger
Ginger
SMILER258
Sep 28, 2015 09:04 AM
