breaking high spec rs turbo s1 zetec turbo
after thinking long and hard about things ive decided i want a 3 door cossy so i have deciced to break,
once i have a buyer for the shell and engine then i will sell all the other items but will hold names to items
rs 3 spoke wheel s1 boss, £110
omp suede flat bottomed wheel £60
koni adjustables good clean order been repainted £110
zetec turbo engine,
supertech forged pistons with valve cutouts 42 psi rating,
eagle steel rods
area six valve springs
arp rod bolts
acl race spec big end and mains
low mileage block 85mm bored to suit for pistons
focus rs head gasket
new timing gear
1.8 sump
genuine ford oil pump cleaned and inspected and shimmed to increase oil pressure,
light head skim for good measure,all valves cleaned refit with new stem seals
£1350
2x s1 lsd boxes bought from members on here both told to be good £125 each
zetec turbo inlet and fuel rail custom made with frst iscv, £160
exhaust manifold originally 200 sx new stainless flanges to convert to zetec and t3 fitment £150 still new
t34.63 turbo reconditioned a while ago but not covered much mileage from a crashed escos £330
megasquirt ecu and ford edis for zetec turbo all been checked with serial cable and disc £250
polished alloy showcage £110
louvred bonnet started to cut for aerocatches £50
13 row mocal oil cooler and sandwich plate £75
vibratechnic gearbox mounts £70
interior decent order £250
dash 2 minor cracks £225
smoked rear lights red and grey, some damaged studs £70
home done smoked rears from my car £40 chipped on osr edge only slightly
s1 kit in decent order with tow eye cover genuine £160
300mm st170 mk3 mondeo front brakes little mileage with spacers £100
rear disc conversion,brackets,hbrake cables,calipers discs £80
stainless 2.5 inch system with outward rolled in very very good order £125
rear anti rollbar and brackets £20
debadged grill £30
headlight scoop made by twins in primer £150 what i paid
clear front indicators new £20
s1 antirollbar setup with clamps, freshly powder coated no bushes but somes with rose joints, £150
s1 antirollbar setup decent order with front joints and clamps £120
full polybush kit full car inc steering rack,shock tops
adjustable front arms £110 new condition
polished charge pipe from lev £30 with samco elbow
ap 220mm 4 paddle clutch little use £100
efi flywheel just skimmed so perfect £70
braided hoses for front and rear specific for rear disc conversion rare i made these personally £50
new clear windscreen in ford packet £50
mk3 loom mfi cutout but decent order otherwise £40
efi tank with uprated frst pump and modified mk3 filler and breather,very rare setup £120
alloy rs turbo filler cap engraved £20
mk3 spot brackets rs turbo £25
hella comet 500 spots with covers £40 mint
lower hella comet 550 spots like new £30
mk3 lockset torch key 1 key fits all except fuelcap £75
chrome top headlights £20 each not very old
pro alloy front mount intercooler and twin fans £200
alloy radiator new never fitted £100
full s1 samcos in blue water and oil £100
rs turbo as heatshield engraved £15
mk4 water pump samco big one £20
polished oil breather £50
polished alloy header tank mk4 £50
nsf arch,front rivot needs repair £50
osf arch rivot hole needs repair £40
the shell ive not had long,
new genuine ford wings,
new genuine ford quarters
new genuine ford inner chassis legs
new battery tray
new fusebox tray
new genuine ford rear panel
must be seen restored on a jig with pics no rot or major work needed,all in high build ready for wetflat and paint £1300
any other bits inbox me,
as said till the shell and engine have buyers then nothing will be released,
it saddens me to do this but i really havent got time to finish it as i work long hours
i will be adding pics soon as i take them
zetec turbo engine,
eagle steel rods
arp rod bolts
new timing gear
1.8 sump
£1350
debadged grill £30
new battery tray
new fusebox tray
sorry to mess people around,
as with most projects they get you down,ive not had a lot of time lately and when i have everything seemed a chore,
could mods please delete as ive sat all morning thinking about it and the mass of parts i have 95% to finish and my best mate offering to give me a hand to get it together means im going to carry on building it
sorry guys
sorry guys
