show me your 2wd hydraulic clutch setups
Old Jun 25, 2013 | 10:32 PM
botters's Avatar
botters
competant bodger
Default show me your 2wd hydraulic clutch setups
any pics or info on 2wd hydraulic clutch setups? its the box side of things im interested in, what parts you used, where from, how much how are they mounted, not bothered about the pedal end as its for a mk2 escort
its external slave cylinder setups im interested in not the overly exspensive mondeo concentric setups with a bit of machined billet for mega money lol
Old Jun 26, 2013 | 09:01 AM
William MK2 Cosworth's Avatar
I don't have one on this computer, but it is relatively easy,
I just got a bit of metal bent to 90 degrees and bolted it to the outside of the bell housing.
on it i just bolted a long slave cylinder, not sure what it is from and made a small
triangle out of a washer so the rod doesn't pass through the fork.
Can't describe it any better so you'll have to wait for me to get home
Old Jun 26, 2013 | 07:05 PM
botters's Avatar
botters
competant bodger
cheers sounds like just the kind of setup im after could you load any pictures? cheers
Old Jun 26, 2013 | 07:45 PM
doga-ot's Avatar
doga-ot
Mark i'm sure there's a thread on here of how to I read it few months ago it was relatively easy and cheap
Old Jun 26, 2013 | 08:08 PM
botters's Avatar
botters
competant bodger
cheers wes ill do a bit of searching
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
