exhaust issue
Old Jun 22, 2013 | 12:00 PM
t5frankie's Avatar
t5frankie
Default exhaust issue
Hi i have a full 3" turbo back mongoose on my sapphire, problem is thats its touching the gearbox/transfer box underneath which is causing a vibration throughout the whole cabin when cruising, im using the correct hangers and everything looks ok, i cant work out why its touching and its making the driving of it a pita, anyone else had this?
Old Jun 22, 2013 | 12:04 PM
Longdog3004's Avatar
Longdog3004
Try twisting centre pipe round a bit when you loosened all the clamps,
Or bending hangers a bit,
Had this trouble on my 4i but ok after twisting centre pipe round a bit
Old Jun 22, 2013 | 12:08 PM
t5frankie's Avatar
t5frankie
iirc its the downpipe thats causing the issue
Old Jun 22, 2013 | 05:04 PM
cossie891's Avatar
cossie891
As above all you need to do is loosen all the bolts and clamps and move the down pipe till it fits right
Old Jun 23, 2013 | 01:34 PM
H15 FSC's Avatar
H15 FSC
if that fails......................get the hammer out
Old Jun 29, 2013 | 03:08 PM
Cossy Mike's Avatar
Cossy Mike
I had the same problem...I took it off and put a second hand system on as the mongoose is such a bad fit.
I re fitted it as its new and fook me was it tight. Proper shit fit no matter what you done with it. You must use poly hangers to stand a chance.
I left the 3 nuts on the turbo loose and propped it up with trolley jack then twisted all of the system until it cleared everything the tightened up the clamps, and last of all the three nuts.
However, I e not put the bumper back on and garauntee it'll be a mile out
Blueflame fit like a glove and have proper flanges in but th entail pipe is slightly to long, that's where my money would have been if I'd of known at the time
JK12
33
Apr 26, 2021 12:09 PM
Mark_
14
Jan 16, 2016 05:27 PM
Cosnada
Jan 7, 2016 05:30 PM
steve.rst
Oct 3, 2015 08:52 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
