p100 to cosworth change question
as above putting a yb cosworth in , question is the outlet from the standard fuel tank ? guessing it will need changed to suit the feed for the 044 pump , is it a case of cut and weld in ? or any ideas would be good .
also thinking about a fuel swirl pot too but will have a read up first .
thanks for any help or info
yea think that's what will need to be done , and once run in and so on around 380/400 , the reason i say about the swirl pot is when the p100 was a diesel and it was under quarter of a tank coming off roundabouts the fuel would move and then starve the engine of fuel , but as its now a carb model pinto it no longer shows that as it has fuel in the bowel of the carb to feed from and so it dose not show the lack of fuel , but with the yb being injection i don't want it running lean or not having fuel to pump , so my idea is the swirl pot and maybe another small tank to act like the bowel of fuel , well that's the madness lol
yep was thinking that , will be putting one in , dose anyone know what level the swirl pot has to sit ie level with the tank / below or above? , next thing is are swirl pots all the same or is there better or worse ones out there? or different sizes ? any info would be good thanks
Aug 14, 2015 07:29 AM
liam-rst
Aug 10, 2015 08:46 AM
