S2 turbo put foot on clutch n it try's to cut out
Coming home from work tonight and came to a stop with clutch pressed down and it went to cut out the red light popped on briefly for the engine!
Any ideas whts the matter with it,
Dip stick n header tank all pushed in n not popped out
It could also be a blocked oil pick up pipe( the one you see when you remove the sump) the carobn build up blocks the gauze and restricts oil pick up.
The oil pump could be worn out aswell. Try these out before considering a worn engine.
Yep..... This would cause an air leak, meaning the car would most likely run lean and not idle so it would cut out at traffic lights etc.... The oil and or battery lights will come on if it idles extremely low say below 500rpm.
i had an issue with one of mine years ago after first buying it, would cut out after a hard throttle took me ages to find the fecking dump valve was sticking open every now and then barstuard thing grrrrr. lol
Sorted it I think! Hasn't cut out n revs picked up well! Idles fine now! It must of been the dip stick or just a funny spell! Thanks for your help guys!
If a dump valve sticks open would wd40 do the job or Greece?
CabrioTurbo
Aug 1, 2015 11:04 AM
