Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus ST225 Power loss
Old Jun 12, 2013 | 11:24 AM
blueovalboy500's Avatar
blueovalboy500
Unhappy Focus ST225 Power loss
Hi.
Hope someone can help me. Please.
I bought a 07 plate focus st225 last December and it was running excellent. It is standard with a decat already fitted when bought.
The last month it has got very flat and unresponsive. I took it to a rolling road who suggested I change the 3 sensors. MAP,MAF AND BCS.
I also had it serviced and did a smoke test as the rolling road guy said I could have a leak somewhere. No leak found. Still running the same after all the new sensors.
Could it be the actuator?
What do you suggest I do next?
CheeRS
Old Jun 12, 2013 | 11:27 AM
Dal_'s Avatar
Dal_
Would you say that it's not boosting correctly and has got gradually worse? Does it make it to 1/2 boost on the gauge? (perhaps a bit more with a decat)
If not then it's likely to be your boost solenoid that's given up the ghost. About Ł40-Ł50 from Ford and a 15 min fit
Old Jun 12, 2013 | 03:34 PM
blueovalboy500
Thanks for the reply Dal. Yeah everything you say is what its doing but i changed the MAF, MAP and BCS which i beleiove stands for the Boost Control Solenoid last week.
I see you mentioned Boost Solenoid. Is this different to what i have mentioned above?
CheeRS
Old Jun 12, 2013 | 03:54 PM
Dal_'s Avatar
Dal_
Ah, no - sorry my mistake.
Might want to check the symposer tube as apparently that has a diaphragm in it that can fail which causes similar symptoms to the BCS going. (Some people blank theirs off to avoid the problem)
You've not got a whistle / noise like a bearing gone on a water pump have you?
Old Jun 14, 2013 | 12:13 PM
blueovalboy500
My mate in Ford's did a smoke test and there was no leak anywhere which i thought i had.
Wouldnt that have picked up the Symposer pipe if it was split?
Im on the verge of maybe contacting scc and getting it in and looked at but its a long way for me and i need the car everyday.
Old Jun 14, 2013 | 12:15 PM
blueovalboy500
I do have a noise but its the aux pulley thats making it and not the alternator as previously thought.
It varies with the engine rev's.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Sep 3, 2015 10:49 AM
