zetec turbo idle help
Old Jun 9, 2013 | 08:59 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Default zetec turbo idle help
Hi ime after some help on how to adjust the idle on my zetec turbo engine. The engine is running pectel t2 managment and a cosworth throttle body, the engine is idling at 2400 and want to set it to 900, I have tryed to adjust the idle screw on the body but it hasnt droped even though its all the way in and i have disconected the throttle cable aswell just incase that is holding it open slightly,is there any thing else I can do to lower the idle? Or will I have to have it remaped as the whole engine spec has changed since it was last maped
Old Jun 9, 2013 | 09:02 PM
studabear's Avatar
studabear
check for airleaks
Old Jun 9, 2013 | 09:05 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Originally Posted by studabear
check for airleaks
Already checked for them and cant find any
Old Jun 9, 2013 | 09:06 PM
studabear's Avatar
studabear
does it use the cossie iscv?
Old Jun 9, 2013 | 09:07 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Yeh its got a brand new cossie iscv on it,
Old Jun 9, 2013 | 09:09 PM
studabear's Avatar
studabear
has it always idled fast or just started doing it?
Old Jun 9, 2013 | 09:13 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
It use to be ok but since then I have changed every thing on the engine including the tb, wouldit need a remap to lower the idle? I know ihave to get it remaped but wanted to get it running ok amd any leaks and issues sorted before then
Old Jun 9, 2013 | 09:21 PM
studabear's Avatar
studabear
does unpluging the iscv do anything? have you got the correct tps required for your ecu?
Old Jun 9, 2013 | 09:29 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Havent tryed unpluging it, will try that, the car was originaly mapped with a frst tb with standard frst iscv and tps
Old Jun 9, 2013 | 09:36 PM
studabear's Avatar
studabear
thats gonna be the problem then,AFAIK your ecu will need reconfiguring to the cossie stuff if your ecu gives these options.
Old Jun 9, 2013 | 09:39 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Thats what I was thinking, looks like I will have to get it remaped
Old Jun 9, 2013 | 09:48 PM
frsjon's Avatar
frsjon
mapping will sort it rob, its running then
Old Jun 9, 2013 | 10:04 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Yeh its running now jon been trying to get it finished for castle coombe next month, but I dont think the car wants to go though, nothing is going to plan lol
Old Jun 9, 2013 | 10:07 PM
frsjon's Avatar
frsjon
hope to see it there!
Old Jun 9, 2013 | 10:11 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
So do I lol, still got a few bits to sort then a mot, but if I cant sort the idle out it wont be going
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
