s1 fuel relay bridging
Old Mar 17, 2005 | 09:56 AM
davie0146's Avatar
davie0146
Default s1 fuel relay bridging
what points do you bridge to get it to stay on contantly?
ta
Old Mar 17, 2005 | 11:35 AM
JesseT's Avatar
JesseT
The think wires for the pump to run non-stop. I think they were red and black/red.
Old Mar 17, 2005 | 11:40 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
top one is | vertical in the middle and the other is bottom _ horizontal in middle also, cant mind what colours or whats top n bottom but u'll see what i mean when u look!
HTH
Old Mar 17, 2005 | 03:04 PM
MJC's Avatar
MJC
as above
Old Mar 17, 2005 | 05:20 PM
mrviper's Avatar
mrviper
i just did that and pump runs with the key removed !
is there another way to get the relay to click when the ignition is turned on??
Old Mar 17, 2005 | 10:50 PM
DazC's Avatar
DazC
Pin 87 and Pin 30.
Pump will run continuously even with the ignition IIRC....
VERY danagerous if you have an accident like this.
Old Mar 17, 2005 | 10:55 PM
Andy-R's Avatar
Andy-R
Davie I know of 2 people that were burned to death after crashing an S2 all because of a hotwired fuel relay...think twice before doing it.
Old Mar 17, 2005 | 11:00 PM
DazC's Avatar
DazC
Yes. For this reason, they are a tachometric relay so cut the fuel off when it senses the engine cut out.
I can repair the relays depending on the fault......
Old Mar 17, 2005 | 11:04 PM
mrviper's Avatar
mrviper
how can i make it work properly with a omex ecu installed
omex can controll a fuel pump but not when the tacho is in use because it only has 1 auxilery cable
Old Mar 17, 2005 | 11:07 PM
DazC's Avatar
DazC
If you are using the tacho then leave the fuel pump relay in place taking care not to remove the green wire between the negative of the coil and the fuel pump relay itself (mounted abouve the throttle pedal).
I have replied in the other post for you...
Old Mar 18, 2005 | 07:34 AM
davie0146's Avatar
davie0146
cheers for the pointers lads
i was just bridging it to see if that was the pob with the car, which it isn,t
so relay getting plugged back in
Old Mar 18, 2005 | 07:43 AM
davie0146's Avatar
davie0146
bridged relay and pump is working fine, but when bdridging the relay i found that the power is 12v but when i try to start it ti drops to between 5-6volts,
im thinking that this drop would be enough to almost stop the pump from pumping enough fuel so that the engine is getting starved of fuel when i try to start it??
cheers
dave
Old Mar 18, 2005 | 03:49 PM
db's Avatar
db
It looks like you will have to take action about your constantly lit battery light.
Check if the alternator is allright. With engine running you should have about 13.5 Volts. With engine off about 12 Volts.
Old Mar 18, 2005 | 05:46 PM
mrviper's Avatar
mrviper
i took the pink relay out and shoved in a standard relay and it works
turn key pump on wheee!!
turn key again pump off!!!
pm me if you want to buy a pink relay
Old Mar 18, 2005 | 05:58 PM
mrviper's Avatar
mrviper
it still works with my imobiliser too
Old Mar 18, 2005 | 09:30 PM
DazC's Avatar
DazC
A normal 4 or 5 pin relay will NOT give you safety against fire in the event of an accident.
I strongly advise you against doing this.
Old Mar 18, 2005 | 09:55 PM
rswoza's Avatar
rswoza
listen to daz, i drove about for a while after doing this and my engine tuner said i was rather stupid. not only are u risking your own life its your passengers.
Old Mar 18, 2005 | 10:47 PM
DazC's Avatar
DazC
And pedestrians...
Old Mar 18, 2005 | 10:55 PM
mrviper's Avatar
mrviper
and cats..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
20/20 vision
Sep 29, 2015 11:27 AM
