knackered rings?
Old Jun 9, 2013 | 08:16 AM
johnboy73's Avatar
johnboy73
Default knackered rings?
hello.when turning my rs zvh over i only have compression in number four cylinder.the car has been sat for about 4 years and i bought it as a non runner to restore to full health.ive been told this could be stuck or knackered but someone says that the hydraulic lifters could be the problem.the car does fire up after about 2 mins of turning over!!!!!any hints or tips would be gratefully received!!!!
Old Jun 9, 2013 | 08:30 AM
Mk4 Rick's Avatar
Mk4 Rick
That is strange what did you get for compression in number 4 cylinder then?Take the plugs out of 1 to 3 cylinders and put a teaspoon of oil down each hole.It will or should make a seal round the rings to test and go from there
Old Jun 9, 2013 | 09:11 AM
COLEYST200's Avatar
COLEYST200
So wot was you told when you got it as you have said it was a non runner when you got it ?????
O plus this post is in the rong place mate
Old Jun 9, 2013 | 11:26 AM
johnboy73's Avatar
johnboy73
ok i will try that.when i bought the car i was told that it maybe siezed hydraulic lifters.i am restoring the car so the engine will be coming out anyway but i just wanted to know what it could be.
Old Jun 9, 2013 | 11:28 AM
johnboy73's Avatar
johnboy73
i dont understand why my post is in the wrong place?i am renovating and restoring my rs?
Old Jun 9, 2013 | 12:19 PM
johnboy73's Avatar
johnboy73
the compression was 150psi on number4,nothing on the other three!
Old Jun 9, 2013 | 12:34 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
It could be that some of the valves are stuck partly open.
Old Jun 9, 2013 | 02:25 PM
rostill2007's Avatar
rostill2007
Think what he means is the post looks like a question for the technical q&a section although if it is a project thread this is the place for it just add some pics so we can all look at what you've got and what you're doing
Old Jun 10, 2013 | 04:13 AM
johnboy73's Avatar
johnboy73
ive got you!i"ll get some photos up asap.
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
