clutch wont bleed need help ASAP
hi guys ive just replaced the clutch on my st170 along with the slave cylinder but now it wont bleed what so ever! ive tried the manual way like you would a brake but nothing. i went a got a pressure bleeder hooked it up open the nipple and still nothing come out. i even tried manual bleeding with the pressure bleeder hooked up but still no fluid coming through. im getting so frustrated now thanks luke
Is the pot full to the brim? The fluid intake for the clutch is usually right at the top, if it's only at 'max' the clutch pot probably can't draw anything in
try sucking it through first then, you sure the new slave hasnt "popped" and is filling the bellhousing with fluid, the amount of times ive had this happen is a joke and is now why, when doing any clutch with hydraulic operation i fit the box with two bolts then bleed the clutch before building the car back up
Go to your local vets (yes, really) and ask for a 50/60 mil syringe, they will probably give you one free.
Fix some rubber/plastic tube on it.
Suck up some clean brake fluid, without any air bubbles in.
Attach to slave cylinder bleed nipple and then open it.
Pump the fluid out of the syringe, effectively bleeding it backwards (the fluid may overflow from the reservoir if it's full)
You may need to do repeat once or twice to get all the air out.
Works everytime and you don't even need to touch the pedal.
Hope this helps
Hope this helps
Ive been trying with that eezie bleed kit got it from gsf. Could my master cylinder be fooked? As ive tried pushing the fluid back up the system and still get nothing coming back to the res just alot of pressure in the syringe
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
