Diff whinning ?
Old Jun 5, 2013 | 06:55 PM
leedsrhinos126's Avatar
leedsrhinos126
Default Diff whinning ?
For the last few days when driving slow and coming to a stop there's a whine coming from the rear end, it sounds as if a tyre is rubbing when driving but by jacking the car up putting it in gear seems to be the diff but can't pin point where the noise is coming from?
Any suggestions? The diff is apperently an lsd
Problem after f***ing problem with this car now
Old Jun 5, 2013 | 06:58 PM
doga-ot's Avatar
doga-ot
lol what engine you got? I have a 2ltr dohc standard 7" push in shaft diff with shafts if you want them
Old Jun 5, 2013 | 07:01 PM
leedsrhinos126
Ye 2ltr dohc but cossie 7.5" diff with Lsd or so i was told when buying the car
Old Jun 5, 2013 | 07:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Check the oil first mate
Old Jun 6, 2013 | 06:39 PM
leedsrhinos126
The diff oil level is good what next?
with the car on the ground the n/s driveshaft has side to side movement and the o/s is solid, its hard to find where the noise is actually coming from
help
Old Jun 6, 2013 | 07:09 PM
fraser9764's Avatar
fraser9764
Sounds like the cv joint, any difference when turning? Didnt you smack a curb a while back? Was it on the side with play in the shaft?
Old Jun 6, 2013 | 07:19 PM
leedsrhinos126
I can only really tell when slowing. smacking the curb was on the o/s, the one with no play in shaft. Only noticed the sound after fitting camber shims.
New cv joints or just buy a drive shaft for the n/s ?
Old Jun 6, 2013 | 07:41 PM
dojj's Avatar
dojj
Resident Wrestling Legend
make sure it's a legit 7.5 cossie diff, they have larger shafts and larger cv's and are 2wd cossie specific so don't shell out any money until you know for sure
Old Jun 6, 2013 | 08:06 PM
leedsrhinos126
Just checked the tag on the diff bit dirty but think it says
9566 JA 364
4A 5H23 0112
mean anything?
Thanks for the replys
Old Jun 6, 2013 | 08:41 PM
fraser9764's Avatar
fraser9764
the bolts into the hub/diff flanges will be M10 if its a true 7.5" diff, M8 if its a 7"
Old Jun 6, 2013 | 08:50 PM
leedsrhinos126
Its defo a 7.5"diff just dunno what shafts now
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
