Just won't go
A mate of mine has built a cossy up from a rolling shell the engine and box etc came out a one we scrapped but it just won't start it's sparking, checked timing ok, changed crank sensor, it's got loads of fuel pressure but seams like the injectors aren't firing. Any ideas guys? What triggers the injectors to fire? It's a g plate 4x4 running an l8 all out of a running car.
went and picked up a saph cossie in the weekend with my brother, now we have one each. Just about home when it flat died. Spark cranked etc. Found a cracked coolant temp sensor plug (under inlet manifold near the rear of the engine) the blue one had fallen off and engine did not run without it. Worth a look!
kev
kev
Also check the 'CTS', an open circuit here will cause the car to run massively rich, which can also lead to a non starter.
Martin
