frst breaking or job lot,high spec
Old Jun 3, 2013 | 02:10 PM
stevos1's Avatar
stevos1
Default frst breaking or job lot,high spec
iv decided its time to move on from rs turbo ownership iv had the car 9 years and iv lost interest now,
im gona list the whole lot in parts with prices.
so here goes
green side mouldings 60
mk3 fiesta read beam polybush mounts new in box 40
group A k&n filter SOLD
bailey breather 50 SOLD
area six cvh over the gearbox manifold and down pipe (need a cossie turbo housing to fit) SOLD
cosworth t3/t34 .48 turbo housing £50 SOLD
1600 cvh turbo engine mount £30
frst stainless exhaust t3 fitment with 4 inch rolled tip back box £150
t3 down pipe to center of the car part stainless £40
rs1600 rocker cover has had the ford motorsport logo cut out smoothed over and moved above the cambelt-SOLD
cosworth 3 bar map sensor £50 SOLD
frst 2 bar map sensor £25
wilwood 4 pot calipers brakets discs & braided hoses needs pads SOLD
frst efi fuel tank done less than 200 miles £40
MSD efi fuel pump rated to 350bhp £45 SOLD
frst recaro seats and door cards £150
frst bonnet in black with red vents and lockable aero catches fitted SOLD
frst red front bumper been cut for a grs intercooler £50
frst side skirts and arches £30 SOLD
efi block with .5mm pistons and shot peened rods with high pressure oil pump, block is cracked so internals for spare 100
spare efi engine in need of a top end rebuild £100
frst master cylinder £20
ofab ecu £80
ahmed bayoo chip for ofab running beiges ect bought of jano from oddkiddcreations £80 SOLD
cossie 2wd engine loom £60 SOLD
cossie 2wd car loom (may have a few plugs missing has the fuse box ect ideal spares) £30
ford racing white faced 30psi boost gauge £80
digital oil pressure gauge with built in volts and sender black out style £25
ford racing engraved bonnet risers £20
AP f 4 paddle clutch plenty of life in it £40 - dibs russrst FT
s2 lsd gearbox £60 - dibs russrst FT
frst radiant red shell has had 2 new outer sills and a patch in passenger and driver footwells petrol cap area is rust free not mint but not rotten either comes with glass rear opening quarters and boot no front bupmer or bonnet £350
felpro rs turbo group a head gasket new £35
new frst head stretch bolts £10
cvh top hat stem seals new £5
corsa b electric power steering unit and ecu controll adjuster and fitting guide with and fiesta mk3 steering columb £100 SOLD
standard 3 bolt cosworth down pipe (splits into two pipes) £30 - dibs Tom9876 FT
frst red charge carrier £30 SOLD
efi inlet with fuel rail and pressure reg £40 SOLD
280cc pug gti6 injectors next step up from beiges £40 SOLD
iw158 380cc injectors sold on area six website at £90 ON EBAY
frst euro rear lights £100 SOLD
puma alloy gear knob £20
AVO coilovers frst (top adjusters move freely no visable leaks) £150 - dibs des789 FT
t3 rst manifold £30
frst t2 manifold no cracks in it £30
frst tps £10
gates cvh turbo cambelt bnib £15
heater matrix frst £20
im located in brighton
pics to follow more detailed on request
Old Jun 3, 2013 | 02:52 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
I will have the turbo mate, pm me details
Old Jun 3, 2013 | 03:19 PM
stevos1's Avatar
stevos1
im not gona break it till the 16th so if no one takes the whole lot you can have dibbs on it mate
Old Jun 3, 2013 | 04:10 PM
stevenebm's Avatar
stevenebm
post whore
Let me know if you will sell the downpipe for the over the gearbox manny.just ordered a new manifold so raging about that!!
Old Jun 3, 2013 | 04:15 PM
jim_jamie_3's Avatar
jim_jamie_3
any more info on the engine? is the gates belt £15 posted?
Old Jun 3, 2013 | 04:17 PM
stevos1's Avatar
stevos1
if i break it mate its gona go with the manifold bud
Old Jun 3, 2013 | 04:20 PM
stevos1's Avatar
stevos1
the engine is spot on mate no knocking or banging no smoke ect
was led to believe its got low comp pistons fitted and the rods have been shot peened the previous owner was a guy on fiestaturbo.com called cowie he ran 21psi through it using a external wastegate and gt28rs theres a thread on his car with it all on there somewhere mate
Old Jun 3, 2013 | 04:23 PM
jim_jamie_3
let me know when its available fella, i wont be runing anything near that lol
just want to use the car
Old Jun 3, 2013 | 04:25 PM
stevos1's Avatar
stevos1
ok mate if it hasnt gone as one lot by the 16th then il let you know
Old Jun 3, 2013 | 04:34 PM
jim_jamie_3
cheers, what about the belt?
Old Jun 3, 2013 | 04:36 PM
stevos1's Avatar
stevos1
yeah mate thats posted if i break bud
Old Jun 3, 2013 | 06:41 PM
Rich87's Avatar
Rich87
I'll take the 280cc injectors and 4 paddle clutch mate if you come to break it
Old Jun 3, 2013 | 06:44 PM
Adam.'s Avatar
Adam.
Yup, no worries
Old Jun 3, 2013 | 06:47 PM
stevos1's Avatar
stevos1
if i break the clutch is spoken for
the injectors you can have dibs on mate
Old Jun 3, 2013 | 07:09 PM
rsturbo27's Avatar
rsturbo27
can i have dibs on the front bushed arms and roll bar cheers
Old Jun 3, 2013 | 07:20 PM
stevos1's Avatar
stevos1
sorry bud been dibsd already
Old Jun 3, 2013 | 07:33 PM
RS 5tu's Avatar
RS 5tu
Im interested in the engine if you have anymore info on it.
Also is the stage 3 head a MFI or EFI head?
Cheers Stu
Old Jun 3, 2013 | 07:43 PM
stevos1's Avatar
stevos1
Cheers Stu
the engine is spoken for, the stg 3 head is efi mate its got brand new valves in and new valve guides it hasnt got a cam tho and would need the rockers ect switching from your existing head to this one as its bear bar the valves
Old Jun 3, 2013 | 07:44 PM
stevos1's Avatar
stevos1
just to add im writing down people who want dibs as i go and that this is advertised on fiestaturbo.com aswell
Old Jun 3, 2013 | 08:02 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
What would you take for the lot including car ?
Old Jun 3, 2013 | 08:15 PM
creator's Avatar
creator
Doh shame your so far away
Old Jun 3, 2013 | 08:18 PM
stevos1's Avatar
stevos1
you have pm
Old Jun 3, 2013 | 08:24 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Second dibs on turbo if Adam doesn't have it.
Old Jun 3, 2013 | 08:33 PM
saman's Avatar
saman
Default cosworth alloys
first on the cosworth alloy wheels mate
Old Jun 3, 2013 | 08:51 PM
stevos1's Avatar
stevos1
ok mate
stevos1's Avatar
stevos1
to late bud
Old Jun 3, 2013 | 09:05 PM
Rich87's Avatar
Rich87
Sorry chap can i have dibs on the iw158 380cc injectors instead of the 280cc
Old Jun 3, 2013 | 09:10 PM
stevos1's Avatar
stevos1
no probs
Old Jun 3, 2013 | 09:22 PM
brianscotty's Avatar
brianscotty
Can I have dibs on the strut brace?
Old Jun 3, 2013 | 09:28 PM
stevos1's Avatar
stevos1
Old Jun 3, 2013 | 09:31 PM
brianscotty
No worries...
Old Jun 3, 2013 | 09:38 PM
scott1987's Avatar
scott1987
can i have dibs on the ofam ecu please
Old Jun 3, 2013 | 09:39 PM
stevos1's Avatar
stevos1
if i break its yours
Old Jun 3, 2013 | 09:42 PM
scott1987's Avatar
scott1987
excellent thanks alot
Old Jun 4, 2013 | 04:28 PM
stevos1's Avatar
stevos1
right all people who've reserved parts il start stripping on the 15th iv decided to break her myself some parts can go before so il be in contact with those whose bits can go sooner. il take paypal or cash on collection or possibly postal order i dont mind posting aslong as its covered by the buyer and if its not to big or again then we'd have to discuss it.
so just to sum it up IM STRIPPING THE CAR ON THE 15TH ITS DEFFINATLY BEING BROKEN NOW
Old Jun 4, 2013 | 04:57 PM
rsmark86's Avatar
rsmark86
Rad, fans, lower arms and roll bar bushes for me will collect ASAP
Old Jun 4, 2013 | 05:02 PM
stevos1's Avatar
stevos1
il pm you bud
i will update the list later with names against stuff
Old Jun 4, 2013 | 08:13 PM
stevos1's Avatar
stevos1
list updated with names against parts
Old Jun 5, 2013 | 09:33 AM
stevos1's Avatar
stevos1
pics can be found here
http://www.fiestaturbo.com/forums/my...date-vt165507/
if anyone wants more detailed pics just ask
Old Jun 6, 2013 | 11:38 AM
Ryoishikawa's Avatar
Ryoishikawa
Pm your way
